I've got multiple polygons on this board I'm laying out. Some want to have direct connetsions to pads and others not.
I was originally adding lots of nets to my rules to allow for direct connections and thought there must be a better way. I originally tried wildcards in the names of the nets in the rules, but that didn't work.
I then had the idea that I could create a netclass called Solid Pour and assign the nets I wanted to have solid connections, to this net class. I did this by right clicking on the net and assigning it to the relevant net class.
In the polygon rules I then created a rule called Solid By Class, put that as highest priority and said when the first object matches Net Class of Solid Pour, the connect style should be direct connect. However, this doesn't work, I still have to go in and add the specific net name to a custom query. I'm going to end up with a custom query a million kilometers long at this rate!
Is there are way to do what I want to do please? Or am I doing essentially the right thing, but missing an important step out? I can see the nets are being assigned to the relevant class.
