I am looking for a lowest V_f possible Schottky diode out there for logic circuits in my designs. So far the best thing I came across is MCL103. It has 200 mV of V_f at 1 mA current. I am not looking for a high current diode (10 mA top is fine) or high blocking voltage one (10 V is fine, although the higher the better). Lowest forward voltage is crucial. What do you use for this end?
Edit: the application: What I need the diodes for is simply to allow current flow only in one direction in glue logic circuits. Because of that, I need a cheap solution in a small form factor. Ideal diodes are too expensive and too big. For example, making an open drain like output from an push pull output, etc.
