I am trying to design a common source amplifier and getting stuck during the design process. Was wondering if anyone can help me out. Ill show my process with comments and if anyone can show me the underlying flaw that would be highly appreciative.
Using this topology With:
\$ V_{in}=1V_{pp} \$
\$ Assuming,\lambda = 0 \$
The process -
Design Spec:
\$ P_{Output} = 5W \$|
\$ R_L = 8\Omega \$
Start by to see how much voltage I need at the output to deliver 5W into the 8Ohm load.
\$ P = \frac{V^2}{R}\$
\$ 5W = \frac{V^2}{8\Omega}\$
\$ V = 6.325V\$, thus at the output I would need a 6.325V to see 5W into a 8ohm load. VDS = 6.325V
Now I would use Large Signal analysis to see whats the current I need in the drain to achieve such a voltage drop across RD in order for VDS = 6.325V using KVL.
\$ V_{DD} = V_{DS} + I_D*R_D \$
\$ \frac{V_{DD}-V_{DS}}{R_D} = I_D\$, but in order to get RD I need to see the transfer function of this circuit. Come back to this equation.
using small signal analysis to obtain the gain of the circuit
Obtaining Branch 3:
\$ \frac{V_o}{V_D} = \frac{Sc2}{\frac{1}{RL}+Sc2} \$
Obtaining Branch 2:
\$ V_D[Sc2+\frac{1}{RD}]+gmVgs = Sc2Vo \$
Obtaining Branch 1:
\$ \frac{V_{gs}}{V_{In}} = \frac{Sc1}{\frac{1}{R1}+\frac{1}{R2}+Sc1}\$
Obtaining Overall Transfer Function:
\$ \frac{V_o}{V_in} = \frac{-S*C2*RD*RL*gm}{S*C2*RD+S*C2*RL+1} * \frac{Sc1}{\frac{1}{R1}+\frac{1}{R2}+Sc1} \$
Here's where I am stuck. Where does one find Gm? Without knowing what VGS is yet how do you find what R1 and R2 is?
However if I where to have all the values I would essentially plug in everything and find RD. Once rd is found ill go back into that KVL question above, find the needed Current then use the \$ I_{Dsat} \$ equation to find the acquire vgs to allow current to follow into the drain that will allow my desire voltage drop across RD.
Please let me know what Iam doing wrong. This been driving me crazy for the past week. I read almost everything online and read some textbook still not understanding. This is where I am at.
