I'm transmitting serial data across a cable to a shift register. I transmit data in discrete packets, where different packets have different bit lengths. The clock frequency is about 20 MHz while transmitting.
When each packet ends, I need to generate a short pulse to latch the shift register. I know a packet has ended when the clock stays low for a few cycles.
What circuit will output this latch signal?
Timing chart example
Commenters asked some good questions about timing, so I'll clarify:
  • The shortest packet is 800 bits, for a duration of 40 μs minimum.
  • Idle time between packets is 10 μs minimum.
  • The latch pulse duration must be 10 nanoseconds minimum.
    \$\begingroup\$ 1) Is the clock rate known, or at least constrained? \$\endgroup\$
    – SteveSh
    Jan 5, 2020 at 22:32
    \$\begingroup\$ 3) Do you need a pulse, or would just a rising or falling edge suffice? \$\endgroup\$
    – SteveSh
    Jan 5, 2020 at 22:41
    \$\begingroup\$ a re-triggerable monostable multivibrator (retrig one-shot) would be the kind of circuit that you are looking for \$\endgroup\$
    – jsotola
    Jan 5, 2020 at 22:56
    \$\begingroup\$ 1st you must be more specific. T1= Duration free of clock transitions ,T2 for duration of pulse and recurring if necessary. With tolerances.. even if you don’t care.... \$\endgroup\$ Jan 6, 2020 at 0:01
    \$\begingroup\$ you want a missing pulse detector \$\endgroup\$ Jan 6, 2020 at 2:34
Thanks to the commenters 🥳, I've come up with a solution: invert the intermittent clock signal, pass that to a missing pulse detector, and pass that output to a falling-edge pulse detector.
Here's a simulation. Click L or H to start or end a packet.
circuit diagram and timing chart
