Can a wire bonder bond wires to contacts on a board like this one: https://www.sparkfun.com/products/8808
\$\begingroup\$ Asking an "is it possible" question is usually a bad idea. It is impossible for anyone to prove that it is not possible, so the only reasonable answer would be "yes, it is possible". But that doesn't get you any closer to actually solving your problem, does it? \$\endgroup\$– Elliot AldersonJan 8, 2020 at 13:12
1 Answer
The surface finish should be something like ENIG (Electrolytic Nickel/Immersion Gold) for reliable wire bonding.
Here are a few other options, none of which is HAL.
