I am trying to get a CD4026 IC to reset at 6 for a digital clock project. I have some 3-input AND gate IC's but there doesn't seem to any unique conditions that would work.
I do have some CD4017 and was thinking I could use them to trigger the reset of the CD4026 IC's at their count of 6, then reset together.
Is pin 5 to 15 a short? Maybe i need power on caps too?
Vs = 5V IC on top is the CD4017
5 and 6 are unique in being the only two outputs where the \$b\$ segment is not lit. The two numbers can then be differentiated based on the \$e\$ segment.
If you have an inverter, then \$\overline{b}\cdot e\$ will tell you when 6 is lit, which can then trigger the reset.
You can also include the \$d\$ segment as an input to your 3-input AND gate for extra resilience against slight delays in the output (prevent glitches when it counts from 4 to 5).
|improve this answer|||||
Not the answer you're looking for?Browse other questions tagged or ask your own question.
