I'm currently trying to implement a simple UART echo application on the ATtiny85, with no additional pins other than RX/TX (no autoflow control).
I'm using the Universal Serial Interface of the ATtiny and basing my work on this article. I've got so far that I can send and receive individual bytes and send them back. However I run into problems when I send more than 1 byte, as the program immediately tries to echo it back before realizing that it's receiving more:
I am very new with stuff this low level and so I am wondering what the correct way to go about this is. I have an internal state that determines whether the device is receiving and currently it switches into sending once a full byte is received.
I am guessing that I have to wait until after the stop bit and see if a start bit follows immediately and only after determining that no other byte is being received, then switch into sending mode. Is this correct and if so, how would I go about implementing this?
here is the code:
#ifdef __INTELLISENSE__
#define ECHO
#endif
#ifdef ECHO
ATTiny85 Hookup
RESET -|1 v 8|- Vcc
PB3 -|2 7|- PB2/SCK
PB4 -|3 6|- PB1/MISO
GND -|4 _ 5|- PB0/MOSI/SDA
ATTiny85 PB0/MOSI/SDA -> Serial UART Rx, connect to Tx of serial input device
ATTiny85 PB1/MISO/DO = Serial UART Tx -> connect to Rx of serial output device
#include <stdint.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "Arduino.h"
#define byte uint8_t
/* Supported combinations:
* F_CPU 1000000 BAUDRATE 1200, 2400
* F_CPU 8000000 BAUDRATE 9600, 19200
* F_CPU 16000000 BAUDRATE 9600, 19200, 28800, 38400
// Set your baud rate and here
#define BAUDRATE 9600
#define STOPBITS 1
// F_CPU defined by Arduino, e.g. 1000000, 8000000, 16000000
// If bit width in cpu cycles is greater than 255 then divide by 8 to fit in timer
// Calculate prescaler setting
#define CYCLES_PER_BIT (F_CPU / BAUDRATE)
#if (CYCLES_PER_BIT > 255)
#define DIVISOR 8
#define CLOCKSELECT 2
#else
#define DIVISOR 1
#define CLOCKSELECT 1
#endif
#define FULL_BIT_TICKS (CYCLES_PER_BIT / DIVISOR)
#define HALF_BIT_TICKS (FULL_BIT_TICKS / 2)
// Number of code CPU cycles from from pin change to starting USI timer
#define START_DELAY (99)
// Number of CPU cycles delay after setting COMPA timer until global interrupt is enabled
#define COMPA_DELAY 42
#define TIMER_MIN (COMPA_DELAY / DIVISOR)
#define TIMER_START_DELAY (START_DELAY / DIVISOR)
#if (HALF_BIT_TICKS - TIMER_START_DELAY) > 0
#define TIMER_TICKS (HALF_BIT_TICKS - TIMER_START_DELAY)
#if (TIMER_TICKS < TIMER_MIN)
#warning TIMER_TICKS too low, USI bit sample will after center of bit
#endif
#else
#error "TIMER_TICKS invalid, choose different values for F_CPU, BAUDRATE and START_DELAY"
#define TIMER_TICKS 1
#endif
// Old timer values
#ifdef ARDUINO
volatile static uint8_t oldTCCR0A;
volatile static uint8_t oldTCCR0B;
volatile static uint8_t oldTCNT0;
#endif
// Serial
volatile bool serialDataReady = false;
volatile uint8_t serialInput;
volatile bool receiving = false;
//---- Send -----
// USISerial send state variable and accessors
enum USISERIAL_SEND_STATE
AVAILABLE,
FIRST,
SECOND
static volatile enum USISERIAL_SEND_STATE usiserial_send_state = AVAILABLE;
static inline enum USISERIAL_SEND_STATE usiserial_send_get_state(void)
return usiserial_send_state;
static inline void usiserial_send_set_state(enum USISERIAL_SEND_STATE state)
usiserial_send_state = state;
bool usiserial_send_available()
return usiserial_send_get_state() == AVAILABLE;
// Transmit data persistent between USI OVF interrupts
static volatile uint8_t usiserial_tx_data;
static inline uint8_t usiserial_get_tx_data(void)
return usiserial_tx_data;
static inline void usiserial_set_tx_data(uint8_t tx_data)
usiserial_tx_data = tx_data;
static uint8_t reverse_byte(uint8_t x)
x = ((x >> 1) & 0x55) | ((x << 1) & 0xaa);
x = ((x >> 2) & 0x33) | ((x << 2) & 0xcc);
x = ((x >> 4) & 0x0f) | ((x << 4) & 0xf0);
return x;
char message[] = "USI Serial\r\n";
void usiserial_send_byte(uint8_t data)
while (usiserial_send_get_state() != AVAILABLE)
// Spin until we finish sending previous packet
usiserial_send_set_state(FIRST);
usiserial_set_tx_data(reverse_byte(data));
// Save current Arduino timer state
#ifdef ARDUINO
oldTCCR0B = TCCR0B;
oldTCCR0A = TCCR0A;
oldTCNT0 = TCNT0;
#endif
// Configure Timer0
TCCR0A = 2 << WGM00; // CTC mode
TCCR0B = CLOCKSELECT; // Set prescaler to clk or clk /8
GTCCR |= 1 << PSR0; // Reset prescaler
OCR0A = FULL_BIT_TICKS; // Trigger every full bit width
TCNT0 = 0; // Count up from 0
// Configure USI to send high start bit and 7 bits of data
USIDR = 0x00 | // Start bit (low)
usiserial_get_tx_data() >> 1; // followed by first 7 bits of serial data
USICR = (1 << USIOIE) | // Enable USI Counter OVF interrupt.
(0 << USIWM1) | (1 << USIWM0) | // Select three wire mode to ensure USI written to PB1
(0 << USICS1) | (1 << USICS0) | (0 << USICLK); // Select Timer0 Compare match as USI Clock source.
DDRB |= (1 << PB1); // Configure USI_DO as output.
USISR = 1 << USIOIF | // Clear USI overflow interrupt flag
(16 - 8); // and set USI counter to count 8 bits
// Call from main loop to read from serial
// returns true if data was read
// data placed in variable at pData address
bool readSerialData(uint8_t *pData)
if (serialDataReady)
*pData = serialInput;
return true;
return false;
// Initialize USI for UART reception.
void initializeUSI()
oldTCCR0B = TCCR0B;
oldTCCR0A = TCCR0A;
DDRB &= ~(1 << DDB0); // Set pin 0 to input
PORTB |= 1 << PB0; // Enable internal pull-up on pin PB0
USICR = 0; // Disable USI. GIFR = 1 << PCIF; // Clear pin change interrupt flag.
GIMSK |= 1 << PCIE; // Enable pin change interrupts
PCMSK |= 1 << PCINT0; // Enable pin change on pin PB0
void onSerialPinChange()
oldTCNT0 = TCNT0; // Save old timer counter
GIMSK &= ~(1 << PCIE); // Disable pin change interrupts
OCR0A = TIMER_TICKS; // Delay to the middle of start bit accounting for interrupt startup and code execution delay before timer start
TIFR = 1 << OCF0A; // Clear output compare interrupt flag
TIMSK |= 1 << OCIE0A; // Enable output compare interrupt
// Will fire for all enabled pin change interrupt pins
ISR(PCINT0_vect)
uint8_t pinbVal = PINB; // Read directly as Arduino digitalRead is too slow
if (!(pinbVal & 1 << PINB0)) // Trigger only if DI is Low
receiving = true;
digitalWrite(PB2, receiving);
onSerialPinChange();
ISR(TIMER0_COMPA_vect)
if(!receiving) {
return;
// COMPA interrupt indicates middle of bit 0
TIMSK &= ~(1 << OCIE0A); // Disable COMPA interrupt
OCR0A = FULL_BIT_TICKS; // Shift every bit width
// Enable USI OVF interrupt, and select Timer0 compare match as USI Clock source:
USICR = 1 << USIOIE | 0 << USIWM0 | 1 << USICS0;
// Clear Start condition interrupt flag, USI OVF flag, and set counter
USISR = 1 << USIOIF | /*1<<USISIF |*/ 8;
void serialReceived(uint8_t data)
serialDataReady = true;
//clearReceive = micros() + (float)(FULL_BIT_TICKS/(F_CPU/1000000);
receiving = false;
serialInput = data;
// Reverse USI byte
uint8_t ReverseByte(uint8_t x)
return x;
// USI overflow interrupt indicates we've received a byte
ISR(USI_OVF_vect)
if (receiving)
uint8_t temp = USIBR;
//Restore old timer values
TCCR0A = oldTCCR0A;
TCCR0B = oldTCCR0B;
// Note Arduino millis() and micros() will loose the time it took us to receive a byte
// Approximately 1ms at 9600 baud
TCNT0 = oldTCNT0;
serialReceived(ReverseByte(temp));
GIMSK |= 1 << PCIE; // Enable pin change interrupts again
// We are still in the middle of bit 7 and if it is low we will get a pin change event
// for the stop bit, but we will ignore it because it is high
if (!receiving)
if (usiserial_send_get_state() == FIRST)
usiserial_send_set_state(SECOND);
USIDR = usiserial_get_tx_data() << 7 // Send last 1 bit of data
| 0x7F; // and stop bits (high)
(16 - (1 + (STOPBITS))); // Set USI counter to send last data bit and stop bits
else
PORTB |= 1 << PB1; // Ensure output is high
USISR |= 1 << USIOIF; // clear interrupt flag
//Restore old timer values for Arduino
#ifdef ARDUINO
TCCR0A = oldTCCR0A;
TCCR0B = oldTCCR0B;
// Note Arduino millis() and micros() will lose the time it took us to send a byte
TCNT0 = oldTCNT0;
#endif
usiserial_send_set_state(AVAILABLE);
const uint8_t ledPin = 4;
void setup()
// Tweak clock speed for 5V, comment out if running ATtiny at 3V
OSCCAL += 3;
initializeUSI();
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, 0);
pinMode(PB2, OUTPUT);
// Send
pinMode(1, HIGH); // Configure USI_DO as output.
digitalWrite(1, HIGH); // Ensure serial output is high when idle
void loop()
if (readSerialData(&serialInput))
//analogWrite(ledPin, serialInput);
while (!usiserial_send_available())
// Wait for last send to complete
usiserial_send_byte(serialInput);
#endif
