I'm currently using a demo-board from sparkfun for quick prototyping of a hall-effect sensor application. The specific chip I'm using is the ACS723-5AB, a Hall-Effect sensor that can measure between -5A and +5A.
Now that I'm done using the demo-board from sparkfun I'm looking to just directly use the sensor chip in my final circuit design.
One of the improvements I wanted to make was to add a low-pass filter on the sensor output for smoothing the signal a bit by adding a simple RC filter, but when I look at the circuit-design of the SparkFun board, they don't use an RC filter but just a capacitor to ground on the output line.
I can't imagine anything drawing current from the sensor output, so decoupling doesn't seem likely. It doesn't really create a filter without a resistor (as far as I know?)
My question is: What is the purpose of capacitor C2 on Viout?
enter image description here link to circuit diagram of daughterboard
Link to sensor datasheet
It probably does because it's likely that the output amplifier will have some output resistance that isn't trivially small. The data sheet tell us two things here: -
  • Output Resistive Load from VIOUT to GND is 4.7 kΩ minimum
  • Output Capacitance Load from VIOUT to GND is 10 nF maximum
This fairly convinces me that the output impedance is not insignificant else why have such a high minimum load AND why have such a high limit for output capacitance; most op-amps would probably go unstable with a load capacitance as high as 10 nF so, I expect that there is an internal output resistor.
An extra means of reducing high frequency output noise.
  • \$\begingroup\$ Thanks for the answer! So if I understand correctly there is an internal resistor and by adding just a cap to the output you basically create an RC filter? If so, what kind of output-cap value range should I be thinking of? (sorry for the probably basic question, quite new to analog electronics) \$\endgroup\$ Jan 9, 2020 at 11:38
    \$\begingroup\$ The maximum allowable is 10 nF (according to the data sheet). Unfortunately the DS gives no clue as to what sort of pass band this will give. \$\endgroup\$
    Jan 9, 2020 at 11:39
  • \$\begingroup\$ Alright, again, thanks a lot for your time and answer :) \$\endgroup\$ Jan 9, 2020 at 11:40
