I have had this cheap set of fairy lights for a few years. Powered by 3xAA batteries.
Recently when they are turned on they start bright as they always were then proceed to get dimmer and dimmer until they reach a low light after a couple of minutes.
The lights stay dim but leaving them off for a few hours causes them to ‘reset’ and then the bright to dim behaviour happens again.
I want to fix them and I can see a resistor inside which I suspect could be broken? Does anybody know why this could be happening and what I might need to fix them?
