I have a transformer with several secondaries, and this is how I'm planing to control the inrush current:
I'm using a resistor to limit the inrush current and MCU will energize the relays after a few seconds to bypass the resistors.
  • Can I use a single resistor and relay on the primary to limit the inrush current instead of using a relay for each secondary?
  • How can I activate the relays without an MCU, using only analog circuitry?
  • \$\begingroup\$ If you use this sort of circuit you should have some way to inhibit the circuitry connected to the power supply from drawing current and dropping excessive voltage across the resistors, otherwise you could still get a large pulse of DC current which could weld the relay contacts closed. \$\endgroup\$ Commented Jan 11, 2020 at 18:54
  • \$\begingroup\$ @SpehroPefhany So what should I do? \$\endgroup\$ Commented Jan 11, 2020 at 19:03
    \$\begingroup\$ Andy's answer, as usual, is a good one. The only caveat aside from a bit of heat, is that it won't limit the current surge by nearly as much if the power is interrupted and re-applied with the NTC hot (assuming the capacitors discharge). If you still want to use a relay find a way to inhibit the circuitry, which may or may not be easy. When I designed a 3-phase motor controller for a sampling system it was easy to not drive the IGBTs until the relay had actuated- common control circuitry. Your details will be similarly dependent on the details of the circuitry attached to the power supply. \$\endgroup\$ Commented Jan 11, 2020 at 19:35
  • \$\begingroup\$ I understand why you deleted your newer question @ElectronSurf - it all gets very complicated when you start to impose one regulation because, that drags in the rest of them. \$\endgroup\$
    Commented Jan 12, 2020 at 0:31
  • \$\begingroup\$ @Andyaka I'm still confused and unsure on what to do but that question wasn't on point, thanks for the help. \$\endgroup\$ Commented Jan 12, 2020 at 6:11
6
Putting inrush protection on a transformer primary is a pretty standard way of doing things because it also handles primary magnetization current inrush problems too.
Avoiding an MCU means having a small timer circuit that, when timed out (having been initially triggered by the instance of power being applied), activates the relay as you show in your diagram.
Or, you could avoid all the complication and use a negative temperature coefficient varistor/thermistor in series with your primary winding. This is a pretty standard solution in many power supplies.
  • \$\begingroup\$ I was going to use an NTC thermistor but after testing I saw it produces a lot of heat which I don't know how to deal with. I saw a circuit somewhere but I couldn't find it now, in that circuit he connected the relay positive side after the capacitors. do you think that would work? \$\endgroup\$ Commented Jan 11, 2020 at 12:39
    \$\begingroup\$ An NTC thermistor produces heat mainly in the first few seconds of power being applied. You could use a relay coil in that position but, remember that you don’t want the relay to activate at too low a coil voltage or that defeats the object. So if your power supply is intended to be (say) 24 volts DC, then use a 12 volt relay in series with a 5.1 volt zener diode thus, if the relay would naturally activate at 9 volts, it will be forced to activate 5.1 volts higher. \$\endgroup\$
    Commented Jan 11, 2020 at 12:44
    \$\begingroup\$ I appreciate it if you please add the schematic of the relay and zener diode to the answer as well. \$\endgroup\$ Commented Jan 11, 2020 at 12:52
    \$\begingroup\$ Unfortunately I can’t manage that task on my crappy tablet thing but, it’s simple enough; zener cathode to DC positive supply, zener anode to relay coil positive end (if polarised), other end of relay coil to DC power supply return node. \$\endgroup\$
    Commented Jan 11, 2020 at 12:56
    \$\begingroup\$ @ElectronSurf Safest and most energy efficient option is a combination of the two, NTC plus relay to short the NTC once started. Most expensive though. Are you mass producing these? Also, it’s most common to put the NTC before the transformer since the magnitizing current into it is also a type of inrush. Requires you to use an approved relay though since you are bridging primary to secondary with it. \$\endgroup\$
    – winny
    Commented Jan 11, 2020 at 13:53
This might look like a good idea, but the EMI might be an issue and if the secondary cap fails, the relay will oscillate.
EMI is created by the Relay contacts (V=LdI/dt) at some voltage with series transformer inductance and load capacitance can also create very high voltage spikes.
There is no evidence or spec that defines that the transformer "caused" this surge. In fact it is more likely that the 10mF Caps caused the surge. If they had a low ESR of 10 mOhm then you can expect a secondary surge of Vout/0.01 ohms.
An PTC NTC / aka ICL can reduce the range of peak current, is also a smart choice operating at 85'C.
Look for ICL specs rated for your load cap of 10mF.
By the way Transformers only cause surge currents in large units with Remanence during a power interruption and re-closure out-of-phase. This causes the peak flux to add to the stored flux then exceed saturation levels. Then XL(f)+DCR impedance drops due to significantly reduced Inductance. Large MVA large cores may hum loudly until stabilized. In this example the only surge is the low ESR caps causing rapid charge currents Vout/ESR that exponentially decay to the load current. This is based on the peak pulse currents because the % ripple voltage also describes the current % duty cycle.
Therefore this can be a bad solution for EMI if not done carefully or a good solution for an Audio power Amp (if done right) as done in my old Technics 100W Rx with a 5 second timer. The caps lasted 20 years,, which I considered OK, then I replaced all the e-caps on 1st sign of problems.
Typically a series Power R, bulk choke L and preload R were used. But this is ancient technology.
Here simulated with low DCR ideal source (secondary)
here with improvements
The more serious problem or annoyance is when the 10 mF wears out, the relay will be a loud buzzer and burn out in minutes as the ripple turns it on and off. So I added a diode and cap to prevent that.
  • \$\begingroup\$ Tony you know I'm just a beginner, I didn't fully understand it. first I have to make sure relay don't make any EMI and for that I need an EMI filter with a big choke and two capacitors on the AC input (primary). second I need to take some precautions steps if the secondary caps fails and add a diode and a cap to the relay to prevent it from oscillating. but if the caps fails I think the whole circuitry after the caps will fail and get damaged too. so what's the point of saving the relay (sorry for my ignorance). then you mentioned PTC thermistor, why PTC thermistor instead of NTC? \$\endgroup\$ Commented Jan 11, 2020 at 18:45
  • \$\begingroup\$ Good catch (Murphy's Law.. if anything can be inverted, it will be) NTC .....NTC + fixed R instead of Relay is also OK. But learn how to define load regulation and unregulated Vmax/Vmin .. also learn to use SMPS and Offline regulators next. \$\endgroup\$ Commented Jan 11, 2020 at 19:04
You asked in a different question (which you removed?) about putting an NTC on the primary and bridging it with a relay.
If you care enough about light load power consumption since an NTC will waste power, have issues going from light to full load and voltage dip while your NTC is heating up or similar, my recommended solution is NTC + relay on the primary side. As Andy said, inrush into your transformer is zero crossing insertion and transformer design dependent, but your NTC will handle that too if you put it on the primary.
The upside of an NTC over a straight resistor is in case your relay fails to open. At tens of watts of load or higher, that resistor will not be possible to have in series during operation whereas an NTC will be, although with some power losses.
The downside of this arrangement, apart from the added cost, is that your relay will bridge the primary to secondary isolation provided by your transformer so you need to use an agency approved relay in respect to coil to contact isolation. Plenty of them in the market to choose from.
Here is a simplified schematic:
  • \$\begingroup\$ I deleted that question because it wasn't on point. after some more research I found the answer that I was looking for, Thanks for the extra info. \$\endgroup\$ Commented Jan 13, 2020 at 18:46
    \$\begingroup\$ @ElectronSurf You are most welcome. \$\endgroup\$
    – winny
    Commented Jan 13, 2020 at 19:42
