I have a device that utilizes a mini USB port to send and receive data. I am trying to figure out how I can hook a micro controller to that mini USB port so that it can also send and receive data.
When the mini USB is desoldered, there are 5 surface mount spots, 4 of which are for VCC, Ground, Data+, and Data-. I could directly solder 4 wires to those surface mounts, but I have two problems:
  • Soldering them is difficult because the surface mounts are very tiny, it requires steadily holding the wires in place, and since the area is so small, the solder crosses over to the other surface mount areas.
  • If there is any way, It would be really helpful if the mini USB was still functional
Is there any good way of achieving this?
Mini USB enter image description here
    \$\begingroup\$ How's that going to work? You can't just parallel devices on the data lines can you? \$\endgroup\$ – Transistor Jan 11 at 21:01
  • \$\begingroup\$ Are you ok with breaking the original device's USB connection? \$\endgroup\$ – user1850479 Jan 11 at 21:03
  • \$\begingroup\$ OP said "so that it can also send and receive data". \$\endgroup\$ – Transistor Jan 11 at 21:06
  • \$\begingroup\$ @user1850479 as in breaking the mini USB? That wouldn't be a problem as I could just solder a new one I guess \$\endgroup\$ – Matt Jan 11 at 21:11
    \$\begingroup\$ Can you add a diagram of how you think this should work. I can't figure out whether the device, the micro or the external device is the master and which are the slaves. Given that you've shown a mini-USB port I guess the original device was a slave but now you hope to permanently connect a micro to it as an optional master. \$\endgroup\$ – Transistor Jan 11 at 22:14
SMD soldering requires a non-trivial amount of training (and flux). You don't want to train on stuff that needs to be in working condition.
And even if you manage to solder wires to these SMD pads, the result will be rather fragile.
USB requires a hub once you wanted to connect more than one device to a port.
Also, USB 2.0 high speed data lines are quite sensitive to impedance mismatch, so even just soldering your additional wires could cause USB malfunctions.
| improve this answer | |
  • \$\begingroup\$ SMD soldering requires practice. If you have sufficient practice and appropriate solder then you don't need to drown everything in flux. \$\endgroup\$ – JRE Jan 12 at 11:49
