I bought a floor lamp for use with a mechanical timer that turns electricity on and off using a set schedule (for example, when you're away but want to convince others that you're still at home).
Unfortunately, this kind of lamp (I bought it at Target) won't work with a timer because when the timer removes power and then later restores it (normally, this turns a lamp on), the lamp stays off until someone touches it with a finger.
The sensor is on the side of the vertical column of the lamp and I can't mechanically access the sensor itself.
Can anyone think of a way to modify the lamp so as to ignore the sensor and light up when power is restored? Thanks!
  • \$\begingroup\$ very simple solution is to get a lamp with a mechanical switch \$\endgroup\$ – jsotola Jan 14 '20 at 2:57
  • \$\begingroup\$ modifying the internal design is easy but that requires you to reveal the design which is not (easy) \$\endgroup\$ – Tony Stewart EE75 Jan 14 '20 at 3:30
If you are an electronic hobbyist, you could build a circuit that simulates a human finger:
You can get a big electrolytic capacitor (e.g. 2200uF 50V) which has the size of a human finger. Then you can move this capacitor on the switch with a servo motor, or you can try to electrically connect/disconnect one terminal to earth to trigger a capacitance change.
