I'm trying to repair a laptop motherboard for a coworker and found a shorted IC. I'm not sure of what it is so i'd like to know if anyone could give me an hint
The IC is labeled 5AF2S and is in SOC70-5 package.
I found out it could be a 3 state non inverting buffer but I'm really not sure.
The motherboard part number is byg43 nm-a601
Edit: Here is a picture i had in my phone. The red circle is the ic try to identify The green circle is something that is gone too ( it only hangs on one leg and show marks of corrosion )
Edit more picture enter image description here
This last one is the green circled part of the first picture Marking is FAL CO it is a zener diode DFLZ5V6-7 enter image description here
Edit: I just bought the schematic It is a power distribution switch G517F2T11U https://datasheet.lcsc.com/szlcsc/1912111437_GMT-Global-Mixed-mode-Tech-G517F2T11U_C356801.pdf
New contributor
grifos is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • 4
    \$\begingroup\$ How do you know it's shorted if you don't know its type? \$\endgroup\$ – Marcus Müller 2 days ago
    \$\begingroup\$ Could you add two photos - one showing the area it is in, and another a close-up? \$\endgroup\$ – rdtsc 2 days ago
  • \$\begingroup\$ Because it's a non starting lapto, and by just puling the power supply, this specific component draws something like 1.5w (0.5A@3.3V), making it burning hot. I should have specified it is seems to be shorted to ground. @rdtsc I'll takes pictures tonight when i returns home \$\endgroup\$ – grifos 2 days ago
The ic is a power distribution switch G517F2T11U https://datasheet.lcsc.com/szlcsc/1912111437_GMT-Global-Mixed-mode-Tech-G517F2T11U_C356801.pdf
The diode is a zener diode DFLZ5V6-7
New contributor
grifos is a new contributor. Be nice, and check out our Code of Conduct.
