Please help identifying this connector:
  • measured pin pitch: 1.25mm (17.5mm/14); may also be 1.27mm
  • 15 pin (female), single row
  • crimp connectors
  • 1.5mm width (thickness)
enter image description here enter image description here enter image description here
photos of the socket:
  • \$\begingroup\$ "measured pin pitch: 1.25 (17.5/14)" What units? Inch? mm? \$\endgroup\$
    – CrossRoads
    Jan 14, 2020 at 19:32
  • \$\begingroup\$ it should be mm, sorry \$\endgroup\$
    – damisan
    Jan 15, 2020 at 14:27
  • \$\begingroup\$ Could that be 1.27 mm? \$\endgroup\$
    – winny
    Jan 15, 2020 at 19:18
  • \$\begingroup\$ > could that be 1.27 mm I don't have access to any calibrated measuring equipment. Using standard office ruler the distance from the left edge of the leftmost socket to the left edge of the rightmost socket is around 17.5mm. If the pin pitch was 1.27 the total distance would be 17.78, so yes, that could be 1.27 mm pin pitch. \$\endgroup\$
    – damisan
    Jan 16, 2020 at 13:11
  • \$\begingroup\$ I've added photos of the matching socket \$\endgroup\$
    – damisan
    Jan 16, 2020 at 14:15
-1
Male versions that would plug onto:
https://www.digikey.com/products/en/connectors-interconnects/rectangular-connectors-headers-male-pins/314?k=connector&k=&pkeyword=connector&sv=0&pv1989=0&pv1790=6848&pv88=97513&pv90=39665&sf=1&FV=-8%7C314&quantity=&ColumnSort=0&page=1&stock=1&pageSize=25
Look at some of those, the bottom of the page has Mating Products to get you to female housings like you are after.
  • \$\begingroup\$ Thanks. I've done digikey, mouser, arrow and tme.eu search to no avail. \$\endgroup\$
    – damisan
    Jan 16, 2020 at 14:13
-1
Looks similar to Hirose DF14 series
    \$\begingroup\$ The DF 14 is unlatched. OP's connector is latched \$\endgroup\$ Jun 8, 2023 at 16:34
