I've used this ESD circuit on four boards for hobby projects. I have had no issues on two boards. On two others, the TVS diode for VBUS conducted when the board was plugged into a USB port, causing an overcurrent condition and destroying the ESD suppressor (the host is grounding the USB shield). The two working boards have probably just not seen a transient on connection.
Is there a better design for this? Should there be a resistor between the suppressor and shield ground? I have not seen this in the reference designs I see published by companies that make TVS diodes and worry this could slow transient response or prevent conduction.
The ESD suppressor in the circuit is a TI ESDS314DBVR, which is four TVS diodes in one package tied to a common ground. Digikey link https://www.digikey.com/product-detail/en/texas-instruments/ESDS314DBVR/296-ESDS314DBVRCT-ND/9745477.
The PTC is a LittleFuse rated for the power requirements of the board.
Schematic
    \$\begingroup\$ Who designed the circuit and to what surge or ESD requirement (EN61000 for instance) was it designed to? \$\endgroup\$
    Jan 14, 2020 at 15:38
    \$\begingroup\$ I think the part is an ESDS314DBVR. \$\endgroup\$
    – rdtsc
    Jan 14, 2020 at 15:54
From the datasheet:
Breakdown voltage, IO to GND is the critical parameter. Some parts may conduct at 4.5V, shorting the 5V VBUS to ground and other may not. This is not a suitable part for VBUS ESD protection.
  • \$\begingroup\$ That's a good find +1 \$\endgroup\$
    Jan 14, 2020 at 15:58
  • \$\begingroup\$ Oh, that is a good find. I missed that in the data sheet. Thank you. \$\endgroup\$ Jan 14, 2020 at 17:32
