-1
Suppose there is a ideal voltage source which can provide infinite power if that is needed in an ideal scenario. Now suppose a resister R is connected across it and the e.m.f is E. So by ohm's law the entire E will fall across R, despite of whatever the value of R is; except for 2 conditions,
  1. If R=0, I=E/0=infinity. So E=IR=infinity*0=0, But if the supply gives E volts out and if the charges dissipates it's Total energy by end of the 0 ohm resistance and with the help of infinite current, then how the voltage across it can be 0 and not E?
  2. If R=infinite, I=E/infinite=0. So, E=IR=0*infinite=0. Again the same thing. How can E be zero when at first E was not zero when supplied?
I know in real world nothing is ideal but here I'm taking an ideal case for calculations. And I also know in case 2 if R=infinite or opened the voltage across it will be E but why the equation is not supporting that? And I'm not sure what will be the voltage in case 1. Is there any asymptote in the E vs R graph which is causing those behaviour in two cases?
    \$\begingroup\$ If you want pure mathematics - then you should take in account "infinities" of different orders (or work with \$lim\$ notation and the involved calculus). Anyway, engineering models do not deal with the extreme cases and call such a cases "non-physical". \$\endgroup\$ – Eugene Sh. Jan 15 '20 at 20:37
  • \$\begingroup\$ I know but can u say why this is happening? and also what do u mean by infinities of different orders? \$\endgroup\$ – Abhirup Bakshi Jan 15 '20 at 20:40
    \$\begingroup\$ Infinity can be of different "size". This is a whole field of mathematics and off-topic here. One thing you should understand - "infinity" is not a number and does not obey the regular arithmetic rules. Again, your calculations might make more sense if you rewrite them in the \$lim\$ notation. \$\endgroup\$ – Eugene Sh. Jan 15 '20 at 20:41
  • \$\begingroup\$ For example, you say infinity*0=0 - which is not necessarily true. Think of \$a=x\$ and \$b=\frac{1}{x^2}\$. Now, if \$x=0\$ then \$a=0\$ and \$b=\infty\$. Right? But what about \$ab\$? Obviously it is \$\frac{1}{x}=\infty\$. So here we get \$\infty\cdot 0 = \infty\$ \$\endgroup\$ – Eugene Sh. Jan 15 '20 at 20:56
  • \$\begingroup\$ Yea its a strange behaviour. need to search more on that topic. \$\endgroup\$ – Abhirup Bakshi Jan 15 '20 at 21:02
Let's try a practical case.
Given a strong 18650 fully charged battery, Li Ion Cell ESR ~ 0.05 ohm 3.7V
If you had AWG 30 magnet wire coiled up to make a little solenoid and somehow it shorted inside, what would be the resistance , R be to make the hottest wire?
Please Cut wire < 1 second, otherwise ...V^2/0.05=273 Watts is explosive. self-heating energy that demands a safety fuse.
What is the short circuit current?
How long would you have before the battery melts down into a fire or explosive hazard?
Don't even joke about it.
  • \$\begingroup\$ Yea, in practical case it's not hard at all to determine what will happen \$\endgroup\$ – Abhirup Bakshi Jan 15 '20 at 21:53
