I have a 10K potentiometer that I'd like to use to control the volume of a piezo transducer/buzzer, which is driven by one or more MCU PWM-capable pins (ranging from 0 to 3.3V). Originally, my configuration looked like this, using a single pin:
I need to adapt this to use a bridge configuration across the piezo buzzer, using two separate PWM-capable pins, similar to what's shown below, except with volume control somehow:
The bridge configuration has a number of advantages, like increasing the overall max volume and allowing emulation of two channels (similar to the Arduboy2 or toneAC library).
Is there any simple way that I can effectively scale two separate signals with the same potentiometer? Preferably, I'd need to stick with simple through-hole components.
Some things I've thought about:
  • Using diodes somehow, maybe in an ORing configuration, but I don't think this will give the desired effect.
  • Since I do have a DAC available on my MCU (SAMD21E), I can mix the two audio signals (square waves) in firmware and output on the DAC pin, using the configuration in diagram 1 to control the overall volume.
Thanks for any help or advice.
  • \$\begingroup\$ with only one speaker it's a single channel output, just use Spehro's circuit. if you actually need to control two signals for some undisclosed reason use a dual potentiometer. \$\endgroup\$ Jan 17, 2020 at 1:32
  • \$\begingroup\$ I get that it's only really one channel, but you're correct that I do need to toggle two signals to emulate two channels. \$\endgroup\$
    – Andrew M.
    Jan 17, 2020 at 2:10
Just replace ground with the other phase.
  • \$\begingroup\$ Thanks for the response. This will give the volume advantage, but not the multi-channel emulation, unfortunately :( \$\endgroup\$
    – Andrew M.
    Jan 16, 2020 at 0:09
  • \$\begingroup\$ I did update the question slightly with some info about ideas of my own. \$\endgroup\$
    – Andrew M.
  • \$\begingroup\$ If you can use the DAC that would be a good solution. Doesn't really lend itself to using PWM-based signals though. \$\endgroup\$ Jan 16, 2020 at 0:15
  • \$\begingroup\$ Yeah that’s definitely a disadvantage. I could still do the mixing in an interrupt thankfully. Not quite as good as toggling the line directly but better than trying to achieve it in the main loop. \$\endgroup\$
    – Andrew M.
    Jan 16, 2020 at 0:30
  • \$\begingroup\$ Or add a real mixer and bridged amplifier on the outputs but that's a bit more involved. \$\endgroup\$ Jan 16, 2020 at 0:35
