I am looking at LM6132 specifically. In the datasheet, the absolute maximum "Current at Output Pin" is +-25mA. Yet Digikey lists it's "Current - Output / Channel" as 4mA...
I assume digikey's value is the "recommended" output current.
The amp will be running off a +-12v power supply and unfortunately, in the section for 24v Vcc, the datasheet has no output current figure...
I am just curious as to what impacts I can expect with regard to life expectancy, if any, running the op amp at 10mA roughly 50% of it's life. That is, the opamp will likely be sourcing 10mA half the time it is powered on and 0mA the rest of the time.
