I have an electromagnetic 7-segment flip display which has 28 electromagnets for 4 digits.
They run on 20V, have a 7.5W power rating and need alternate polarity applied to switch between the 'on' and 'off' states.
I tried using a Raspberry Pi with 14 x L298N Dual H-Bridge Driver Modules to run the electromagnets and it usually works, but there's a lot of wiring involved with the H-Bridge modules, making fault-finding tricky, and I've had a few fail on me already.
Is there a better/tidier way of controlling them that I haven't come across? I've done research online but can only really find these H-Bridge modules as being the answer.
Thanks.
  • \$\begingroup\$ This is a pretty broad question... but if you're desire is to reduce wiring, you could obviously go wireless between the raspberry pi and the motors, dedicating a wireless controller to each motor, and communicating command and control to them by, e.g. a broadcast protocol. AFAIK there's no way to get bi-directional control of a DC motor without an H-Bridge in play. \$\endgroup\$
    – vicatcu
    Jan 17 '20 at 17:56
  • \$\begingroup\$ How long does 20V need to be applied for the display element to flip reliably? Do you want to be able to flip them all at the same time (will require a big power supply) or is it okay to flip them one at a time? \$\endgroup\$
    – bobflux
    Jan 17 '20 at 21:33
  • \$\begingroup\$ What is the physical dimension of the 7segment display and can it be mounted on a pcb? \$\endgroup\$
    – bobflux
    Jan 17 '20 at 22:18
  • \$\begingroup\$ somewhat related: electronics.stackexchange.com/q/265399/7036 \$\endgroup\$ Jan 17 '20 at 23:32
Another possibility would be to use the DMOS power shift registers in TI's TPIC series. This shows active pullups on each output. You could use resistors but that would come with other issues.
7 is the minimum number of shift registers required, but it might be better to use 8 and then each digit would be identical.
  • \$\begingroup\$ Would this still require the use of the H Bridges? \$\endgroup\$ Jan 17 '20 at 21:32
  • \$\begingroup\$ No, this uses the power SR (and the external parts) to replace the H-bridges. \$\endgroup\$ Jan 17 '20 at 21:39
  • \$\begingroup\$ Thanks. I'll look into this as it sounds promising. \$\endgroup\$ Jan 17 '20 at 21:40
  • \$\begingroup\$ Note edit to correct diode position. I'm not sure you need D1/D2 but there is no spec on maximum base-collector current so I'm leaving them. \$\endgroup\$ Jan 17 '20 at 23:04
  • \$\begingroup\$ Thanks. Do you have any particular Zener diode in mind for D1/D2? \$\endgroup\$ Jan 19 '20 at 13:35
You have 28 bipolar electromagnets so it's difficult to use a matrix arrangement unless they will reliably not flip with 1/2 voltage. Diode isolation won't work. I suppose you could consider putting a bipolar TVS in series with each coil, and boosting the drive voltage (already pretty high for the driver though). Targeted coil sees +/-(Vs - Vz), non-targeted coils see +/-(Vs - Vz)/2.
For that to work you would need drivers (quantity more than \$2\sqrt{28}\$ , eg. 5 x 6 matrix, total 11, that can be driven high, low or high-Z so still 22 control lines at the driver level).
If they won't do that you actually need to control 56 logic states at the driver inputs. So maybe you could flip one at a time and common one of them up (29 wires), but I would think a shift-register would be superior. 74HC595 x 7 pieces. Needs 3 GPIO (or fewer, with tricks) from the RPi. You can use RS-485 with terminated twisted pairs or RS-232 (low speed) drivers/receivers for the lines if you want the display remote. CAT-5 or similar cable could be used.
  • \$\begingroup\$ Thanks, this looks interesting. Where would the outputs from the 74HC595 go? Presumably there wouldn't be enough voltage or current to drive the segments' electromagnets directly. \$\endgroup\$ Jan 17 '20 at 19:14
  • \$\begingroup\$ It's just to control the H-bridges. \$\endgroup\$ Jan 17 '20 at 19:23
  • \$\begingroup\$ Ah I see - makes sense now! \$\endgroup\$ Jan 17 '20 at 19:39
  • \$\begingroup\$ @Spehro Pefhany I've been looking for a similar solution and i've just come across your solutoin involving the shift registers and the circuit you showed above. Can you please edit your answer to explain how the circuit works and what it does as I'd like to learn. Thank you. \$\endgroup\$
    – grog209
    Jan 26 '20 at 18:10
It can be done with a diode matrix in a similar fashion to what is done with ferrite core memories as they also require bipolar operation.
Although core memories extend the matrix drive by exploiting the 1/2 current drive with coincidence selection of the X and Y axes this could not be exploited here. Selected coils would receive full drive, unselected coils zero drive.
Arrange the 28 coils as a 7 by 4 matrix. With each segment using a bipolar drive (using for example 4 x L298N devices). The other axis would require separate drive high and drive low outputs that could also be driven by 4 x L298 devices for a total of 8 devices rather than 14. It would however need 64 diodes to avoid cross-driving of unselected coils.
It would be similar to this: (taken from Magnetic Memory Core System). The display drive coils would replace the individual memory cores.
  • \$\begingroup\$ You sure this will work? Cores don't conduct so you don't have the sneak path issue with a core array. Am I missing something? \$\endgroup\$ Jan 17 '20 at 20:20
  • \$\begingroup\$ @SpehroPefhany - the cores don't conduct but the wires do - driving the display actuators is similar to one axis of a core array. Since there are multiple display coils connected to each driver there are sneak paths. \$\endgroup\$ Jan 17 '20 at 20:55
Don't dismiss the possibility of using relays.
Figure 1.
  • Figure 1a is, in effect a H-bridge. The polarity on the coil is reversed when the relay is energised. This suffers a major disadvantage that the coils, which are probably intended to be impulsed, are powered continuously and may burn out.
  • Figure 1b gives a simple solution to the impulse problem. As shown, the initial condition is relay off and C1 discharged. If the relay is energised a current will flow through RLY2 and L2 into C1 and the segment will be kicked reverse. As C1 charges up the current will fall and when fully charged no current will flow through the coil, prolonging its life.
  • When the relay drops out C1 will discharge through L2 kicking it in the opposite direction. When C1 is fully discharged no further current will flow.
This solution could be implemented with the cheap microcontroller driven relay modules. You'd need a common and, perhaps, a positve supply to the display board and 28 wires - either control signals (if the relays are local to the display) or wires to the inductors (if the relays are remote from the display).
The value of C1 would need to be calculated and tested.
Figure 2. Diodes will help protect the relay contacts from arcing damage.
It's up to you whether or not to use the diodes. If the relays are beefy relative to the current being drawn then you might not need them.
If you used lots of small pcb modules with L298's on them then I guess current pulses in ground wires are going to cause a lot of ground bounce, that is the GND voltage on each module is going to spike pretty bad when they switch. Problem is, no current is flowing in the digital signal wires so you can end up in a situation where the Raspberry Pi outputs 0V, and the ground on your L298 module spikes up a few volts, and it ends up with a negative input voltage (relative to its local GND) which could fry it since its maximum rating for input voltage is only -0.3V when going negative.
Also L298 does not include freewheeling diodes, this means you have to add them to drive inductive loads as per datasheet application schematic. Do your modules include these diodes or not? Each module also requires an electrolytic supply decoupling cap if the supply wires are long.
So the solution using modules is quite a mess. Why not make a nice pcb?
Now, there's someone on the internet who already did a project like that and published schematics...
This is similar to the schematic in Kevin White's answer with multiplexing. Each coil needs a dual diode, which might be already included into the digit assembly or not.
This multiplexing requires 4 "column" lines (one per digit) and 7 "row" lines (one per segment).
No need for H-bridges, you can use ULN2803A and its high-side equivalent MIC2981 for driving both polarities.
Now, it may not be cost-effective to multiplex your digits. If the digits are big enough that the four do not fit on the cheap 10x10cm PCB format from the usual Chinese internet suppliers, and you need a larger PCB... and since you get five PCBs for the price of one... then it will be cheaper to make one PCB per digit. In this case I'd just put one MIC2981 and one ULN2803A per board, with the shift registers or I2C IO expanders to drive them, and supply decoupling caps.
