I made a simple emitter follower headphone amp using fairly high speed BJT- 2SC5994.
Vcc 16V
R1- 10K
R2- 40k
RE- 100
load - 300 ohm
After powering up there it was clear there was serious issue, the amp would pop in and out oscillation randomly. This manifested as buzzing sounds through headphones and after checking with cheap 2mHz oscilloscope there were HF oscillations clearly visible.
They are high speed transistors so this was anticipated, Firstly I added some resistance at the output to isolate from headphone's capacitive load. This seemed to make it less prone to popping into oscillation but it would push up the output impedance too much so wasnt a suitable solution.
Surprisingly adding resistance to the base input ('base stopper') also fixed the problem. With 40 Ohm there hasnt been any oscillation when loaded with HPs and playing test tones of various frequency.
So if it wasnt capactive load on the output causing the issue what else could it be?
