This can be categorized as duplicate question with question in the link below, BUT the reason I ask this because the answer in that question DOESN'T ANSWER the question on how to unhide hidden pins in proteus. The answer in that question only shows a workaround, not the real answer to the question.
How to unhide hidden pins in proteus?
Let's get into it. How to force proteus to show hidden pins, so it doesn't require me to create external switch in real life outside proteus which quite messy, or so I don't need to detach my battery just to TURN OFF microprocessor with hidden pins such as ATMEGA8535 and ect which always connect to the power source.
If it require me to copy and modify the model of ATMEGA8535 in Proteus and edit it so it will show hidden pin, and import it back to proteus. How do I do it?
Or maybe there is actually already exist a way to do this? I'm a beginner and please don't say
"It's easy just do this and that and you done "
Step-by-step please.
