I am very new to electronics and drawing isn't my strength either, so please forgive the bad diagram. But I hope it makes sense.
I want to be able to control a motor using relays and be able to change the direction of the rotation. From what I know, the rotation can be reversed by changing the power to negative and positive terminals. As far as I could understand, I won't be able to do that with one relay. So I plan on using two relays. The diagram shows this (badly). Basically the dashed lines represent circuit for one directional control and the solid lines show circuit for opposite direction.
As I am sharing the battery for both relays, when either of the relays are in open state the cable for the other circuit that is connected from motor to the battery would cause a short. To overcome this issue I will use a diode on both cables that run from motor to battery terminals.
So I guess the questions are,
Does my plan seems reasonable? Is there a better way of doing what I want?
