I am trying to repair a PCB that controls a camping fridge, in the process of reverse engineering the circuit I have got stuck at the device in the top left of the below photo marked K17h I believe this is either a transistor or op-amp used to amplify the voltage drop from the large shunt to the right.
Is there any way I can identify this component, and ideally find a pinout? I have searched for K17h but turned up nothing. Is there a database of these SMD codes kept anywhere for reverse engineering purposes?
Close up
I think it's a SD5054 lithium battery charge manager by Shouding.
It looked like a sot-23-5 package to me so I found this product page by searching on google: "k17h" sot-23-5.
In the datasheet you'll find some info (in chinese) about the naming of this chip. It says there:
k1XY
XY=日期代码
In google translate "日期代码" translates to "Date code"
To answer your question about a database for SMD codes, you'll find some smd code books on google, for example this book which I sometimes use.
  • \$\begingroup\$ so XY=7h = 2017 8th month \$\endgroup\$ Jan 20, 2020 at 13:37
  • \$\begingroup\$ I don't think this is the component, unless it is being used in a creative way. There isn't any lithium batteries in this product, I believe this is being used to monitor for over-current of a cooling fan. That SMD codes link looks very handy and I have bookmarked it even though it doesn't help in this case. \$\endgroup\$
    – Hugoagogo
    Jan 20, 2020 at 21:22
  • \$\begingroup\$ My guess is comparator. Top two pins being in plus and minus, one of the bottom ones being output... \$\endgroup\$ Jan 21, 2020 at 0:55
