This question is related to this one. But the focus is a little different so I put it here.
I tried to understand the detailed working steps of below circuit. It is an old 3T1C DRAM cell circuit. This picture is quoted from the book Memory Systems by Bruce Jacob.
I think the input capacitance of T2 is just a representation of the T2's characteristic, which is not a real capacitor. I know that conceptually capacitance is defined as the ratio of q/V.
My first 2 questions are:
  • Does this input capacitance of T2 mean the ratio between the charges q and voltage V required to open T2's gate?
  • If the charges remain on T2, will T2's gate stay open?
Below is my understanding of the circuit steps:
I guess:
  • write rowline is active-high
  • read rowline is active-high
  • write bitline is active-high
  • read bitline is active-low
Steps to Write and Read "1" to and from the cell
Steps:
  1. write rowline goes to high to signal the write operation. T1 is opened.
  2. write bitline goes to high because we are writing 1.
  3. write bitline reaches T2 through T1. T2 is charged and opened.
  4. write rowline goes to to low to finish the writing. T2 is charged and opened.
  5. read rowline goes to high to signal the read operation. T3 is opened.
  6. read bitline reaches T2 through T3.
  7. Because T2 is opened in 3, 4, so read bitline further reaches ground through T2. So read bitline reads 0 (ground).
  8. Because read bitline is active-low, so the 0 voltage in 7 is interpreted as a logical 1.
Steps to Write and Read "0" to and from the cell
Steps:
  2. write bitline goes to low because we are writing 0.
  3. write bitline reaches T2 through T1. T2 is not charged or opened.
  4. write rowline goes to to low to finish the writing. T2 is not charged or opened
  7. Because T2 is not opened in 3, 4, so read bitline reads the voltage of read rowline through T3, which is high.
  8. Because read bitline is active-low, so the high voltage in 7 is interpreted as a logical 0.
Am I correct?
It is the intrinsic gate capacitance of T2. It is where the bit is stored in this DRAM cell.
Yea, but there is leakage current and eventually capacitor will get discharged in order of milliseconds. This is the biggest drawback of DRAM cells.
Since we assume MOSFETs like switches here, it is more logical to use terms 'closed' for ON state and 'opened' for OFF state. You have used it the other way in your explanations.
There are some problems in steps 5, 6, 7, 8 of "Steps to Write and Read "0" to and from the cell" which seems like comes from the misunderstanding in MOSFET's switching operation.
After writing '0', the capacitor has discharged to zero and T2 is off now.
When read rowline goes high later, T3 remains off -- because T2 is off, and hence the source terminal of T3 doesn't pull to ground.
Since both MOSFETS are off, read bitline is not pulled to ground either. The read bitline should already be pulled up to Vcc thru a pull-up resistor, and therefore it is read as 'high', which is then interpreted as logic '0'.
|improve this answer|||||
    \$\begingroup\$ Thanks. So it seems the circuit graph is not complete. Some pull-up resistor is missing. I hope I can find a complete one. \$\endgroup\$ – smwikipedia Jan 22 at 12:03
  • \$\begingroup\$ Yea it looks so abstract. \$\endgroup\$ – Mitu Raj Jan 22 at 12:04
