Implement the following circuit:
Note that this is a latch, so a Quartus warning about having inferred a latch is expected.
This is my implementation
module top_module (
input d,
input ena,
output q);
always @(*)
    begin
        if(ena==1'b1)
            q=d;
        else
            q=q;
    end endmodule
Can someone help me why there is a inferred latch even though i am solving q for every case possible?
  • \$\begingroup\$ If you are implementing D flip flop, you need a clock. The verilog implementation can be found here, asic-world.com/examples/verilog/d_ff.html. Your implementation is actually a latch. \$\endgroup\$ – X J Jan 22 at 17:41
It's a latch because you allow q to be updated when ena goes high or any time d changes when ena is high. This is exactly the behavior that describes a latch. This is how you should code a latch if you intentionally want to produce one.
To generate a flip-flop you should make the block triggered by a change in ena (i.e always @(posedge ena)) rather than by any change in the inputs.
|improve this answer|||||
