I am using code composer studio and using the microcontroller below, I used Energia software to run a simple program and it runs, but when I use CCS and try to flash an example program for this MCU provided by ti , it gives me an error message . I think that problem is from target configuration file .
In the target configuration file : I set the connection Stellaris In-Circuit Debug interface, and Board or Device : Tiva TM4C1294NCPDT.
Then this window pops up:
U
I realized what I've to do. I need root privilege,so I have to update the .desktop file of code composer.
$ nano 'Code Composer Studio 9.2.0.desktop'
I edited the file to be :
[Desktop Entry]
Type=Application
Version=0.9.4
Name=Code Composer Studio 9.2.0
Comment=Launches CCStudio
Icon=/home/abdo/ti/ccs920/ccs/doc/ccs.ico
Exec=sudo /home/abdo/ti/ccs920/ccs/eclipse/ccstudio
Terminal=true
Path=/home/abdo/ti/ccs920/ccs/eclipse
then, it works properly.
| improve this answer | |
