I have a 8051 micro controller ,it has timer0,1,2,3 with different modes.
in timer0,mode0, i got a sample code (as shown below).
datasheet 8051
from that code
TH0_INIT=0xFC          //5.0ms@XTAL=12MHz, Period = (10.85/2) ms@XTAL=22.1184MHz
TL0_INIT=0x0F
both TH0,TL0 load with hex values..but could not derive these values from equation below . (website) Could you please tell me, how these hex values derive?
tick = (1/(Fosc/12)
tick = 12/Fosc$$ For Fosc == 11.0592Mhz, the tick time will be
tick = 12/11.0592M = 1.085069444us = 1.085us
Delay = TimerCount * tick
        Count = (Delay/tick)
        RegValue = TimerMax- Count RegValue = TimerMax-(Delay/tick) = TimerMax - (Delay/1.085us)
        RegValue = TimerMax-((Delay/1.085) * 10^6)$$
source code for timer0,mode0
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "Function_define.h"
#include "SFR_Macro.h"
#define TH0_INIT                                                               \
  0xFC // 5.0ms@XTAL=12MHz, Period = (10.85/2) ms @XTAL = 22.1184MHz
#define TL0_INIT 0x0F
void Timer0_ISR(void) interrupt 1 // interrupt address is 0x000B
  TH0 = TH0_INIT;
  TL0 = TL0_INIT;
  P12 = ~P12; // GPIO
  toggle when interrupt
void main(void) {
  TMOD = 0XFF;
  Set_All_GPIO_Quasi_Mode;
  TIMER0_MODE0_ENABLE;
  clr_T0M;
  clr_T1M;
  TH0 = TH0_INIT;
  TL0 = TL0_INIT;
  //    set_ET0;                                    //enable Timer0 interrupt
  // enable Timer1 interrupt
  set_EA; // enable interrupts
  set_TR0; // Timer0 run
  while (1) {
    TH0 = TH0_INIT;
    TL0 = TL0_INIT;
    set_TR0;
    while (!TF0)
    clr_TR0;
    P12 = ~P12;
    TF0 = 0;
  • \$\begingroup\$ What is the delay you are looking for? What value of register are you getting? Mode 0 is only 13 bit mode which means counts of only upto 0x1FFF possible \$\endgroup\$
    – User323693
    Commented Jan 25, 2020 at 12:57
For mode 0:
  1. 8192 is the number of ticks available before the timer overflows (13 bit mode).
  2. Assuming 12MHz clock, the timer will be clicking at 1 MHz.
  3. One tick is equal to 1 us
  4. Let us compute counters for 5 ms
  5. Register value is 8192 - 0.005/1u.
  6. So the counters should have value of 3192.
  7. Timer higher byte = 0x0C
  8. Timer lower byte = 0x78
  • \$\begingroup\$ But...why ..TH0_INIT=0xFC TL0_INIT=0x0F? \$\endgroup\$
    – RAVI
    Commented Jan 25, 2020 at 14:07
  • \$\begingroup\$ @RAVI that nearly comes to about 1 ms.. since mode 0 only supports 13bit, there is no way the counter valid values can be higher than 0x2000. Does the code run? Can you check once and validate \$\endgroup\$
    – User323693
    Commented Jan 25, 2020 at 15:17
