I have a Bosch power drill, the same as in this other question.
I checked it carefully and it doesn't seem to have a capacitor or any other electronic components.
  1. Does it mean the universal motor in it runs directly with the 240VAC?
  2. Does it also mean that the rotational speed of the drill is 60Hz?
  3. Can someone explain to me how that is possible? (I am new to electronics.)
  • \$\begingroup\$ take the trigger mech apart, that's where you'll find them \$\endgroup\$ – Neil_UK Jan 25 at 17:57
    \$\begingroup\$ Basically, the trigger has a triac inside. This question has been answered here already: electronics.stackexchange.com/questions/167556/… \$\endgroup\$ – Natsu Kage Jan 25 at 18:08
  • \$\begingroup\$ If you have an old single speed drill, yes this could be the case. \$\endgroup\$ – Ron Beyer Jan 25 at 18:09
    \$\begingroup\$ 1. Yes it is a universal motor. 2. No the speed is related to voltage rather than frequency. 3. A universal motor is like a series DC motor. You should be able to find on the internet a nice detailed explanation of a universal motor with illustrations. The question you linked shows how the electronics of a variable speed motor might be hard to recognize. Comments in that question tell a little more about universal motors. Also check other questions with the [universal-motor] tag. \$\endgroup\$ – Charles Cowie Jan 25 at 18:59
  • \$\begingroup\$ I see No electrronic component in the trigger. It has two inlet leads (live n neutral) n 2 out leads ( one wire to each field coil) . the other field cables are connected to the direction switch . each brush has one wire connected to the direction switch. \$\endgroup\$ – friendlyengineer Jan 26 at 19:48
