I recently got a PIC32MK 100-pin Motor Control Plug-In Module (PIM) I have been trying to prgram it but I have been running into the following error:
Target voltage detected
Unable to connect to the target device.
Failed to get Device ID
I am currently connecting my 3.3V source to pins:
PIN 2 (IN THE MICROCONTROLLER) as VDD (connected to + side of the source)
PIN 15 (IN THE MICROCONTROLLER as VSS (connected to the - side of the source)
I am conneceting the pickit 3 to the following:
Pickit Pin 1 (the one with the arrow): PIN 13 (IN THE MICROCONTROLLER) as MCLR
Pickit Pin 2: PIN 16 (IN THE MICROCONTROLLER) as VDD
Pickit Pin 3: Pin 36 (IN THE MICROCONTROLLER) as VSS
Pickit Pin 4: Pin 27 (IN THE MICROCONTROLLER) as PGD
Pickit Pin 5: Pin 26 (IN THE MICROCONTROLLER) as PGC
Pickit Pin 6: Not connected
Here is the source of where I am getting the values: (Note I have the 100 pin so I am using the diagram in page 5) http://ww1.microchip.com/downloads/en/DeviceDoc/PIC32MK_GP_MC_Familly_Datasheet_60001402G.pdf
the code I am attempting to upload to the Pic is the following:
https://drive.google.com/drive/u/0/folders/1irJj6f744SAhsiNDJO9QxzUNfxEsFJPe file called PWM-centered-interrupt...
Am I connecting to the wrong pins? any help would be appreciated.
  • \$\begingroup\$ Did you check all items described in chapter 2 of the datasheet (decoupling capacitors, pullup in MCLR, no components influencing PGECx/PGEDx, etc) \$\endgroup\$
    – Huisman
    Commented Jan 25, 2020 at 21:23
  • \$\begingroup\$ I did! recreated the MCLR configuration but still nothing \$\endgroup\$ Commented Jan 26, 2020 at 14:37
  • \$\begingroup\$ You probably didn't! Carefully check all items again, also the very first bullet (which may cause your issue): The following is a list of pin names, which must always be connected: All VDD and VSS pins (see 2.2 “Decoupling Capacitors”) You only connected pin 2 and 15 and maybe pins 16&36. \$\endgroup\$
    – Huisman
    Commented Jan 26, 2020 at 18:02
Carefully check all items of chapter 2, also the very first bullet (which may cause your issue)
- All VDD and VSS pins (see 2.2 “Decoupling Capacitors”)
You write you only connected pin 2 and 15. The connection to pins 16&36 you write about only count when you turned on the option the PicKIT is powering the device (which I'd advise against in this case).
Do connect all power pins to the power source and provide a decoupling capacitor as close as possible to each Vdd/Vss pair.
