What's the name/type of the dense foam that's generally used in consumer electronics to stop components from vibrating around and tightly packaging everything together? In my case, this would be for mounting the battery against the back of the PCB and keeping the battery from moving around inside the enclosure. Been searching the traditional electronics part sellers and couldn't find anything suitable.
PS: Would prefer not to use sticky tape as the battery is supposed to be removable.
Thanks!
