Camera wire colours
- Unshield
- Green
- Yellow
- Orange
- Red
- White
- Brown
- Unshield
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityCamera wire colours
I had the same problem on a webcam salvaged from an eeepc, model e85792 ck77 94v-0, very similar to yours, only the wiring colors were different. Here is a picture:
I couldn't make it work but here is a semi-answer, so maybe you can. Please note that I have very little knowledge of electronics.
I couldn't find any datasheet for this webcam so I tried on my own with a multimeter. In my case, there were, from left to right (bottom to top on your image):
As you can see here, you will need 2 1N4001 Diodes, but I had none so I used 1N4007, in the same design as on the link. I had the exact same result by connecting directly (without diodes) the GND and VCC to a 3.3V power supply.
I connected those cables to the USB, on which red is VCC and black is GND, and tried both wirings for DATA cables.
This worked, as my computer showed a "USB2.0 webcam is plugged in" notice message (instant nerdgasm).
Unfortunately, as soon as I launched the "Camera" Windows 10 application, the webcam just rebooted indefinitely, with a LED flashing along with a USB plug-unplug sound each time.
If you are still trying, I'd be glad to hear your feedback.
