I am working on a new project which uses wireless power transfer.
I know that wireless charging in general is not so effective but my circuit is extremely not effective. Can I ask you for some advice?
I attached a picture of my circuit:
Basically it is just modified Royer oscillator, supplied by 5V DC and using logic level transistor to turn on even with 5V.
This circuit has load 47 ohms however later I would like to connect and charge a battery. As a coil I use a planar coil with litz wire with diameter 40mm with resistance less than 0,1 Ohm.
I also attached a picture of my circuit on breadboard. I am limited with frequency which should be 150 kHz in maximum.
I have already tried plenty of experiments but still dont have a solution. When the receiver coil is placed far from transmitter circuit so no load attached, transmitter takes 5V and something around 150-200 mA. When I am move the transmitter coil closer to the receiver coil, at 1 cm distance current flows through 47 ohm load (around 50 mA) but source gives to transmitter almost 600 mA.
I also noticed that when coils are in touch source gives almost 1 A and chokes and transistor heat up rapidly and transmission doesn't work correctly. It seems that transistors don't fully open. I have plenty of coils and I have not reached higher efficiency with any of configurations more than 15 percent.
Maybe the Royer oscillator is not a good candidate for such a circuit, but I really like it for the simplicity and few components, but I have no idea how to increase efficiency.
