I am looking at a part of the datasheet for a hydrophone I am using in a project. It includes this figure, which plots resistance, impedance, and reactance vs. frequency:
Part of my project involves designing a preamplifier for the hydrophone. Because the output of the hydrophone will be in the range of 20 to 40 kHz, I must make the input impedance of the preamplifier much greater than that of the internal resistance of the hydrophone to maximize voltage transfer between the two.
When looking at this chart, I am unsure of which value I need to use for the equivalent series impedance. The parallel capacitance of the hydrophone is 3.4 nF, and its datasheet can be found here.
