I'm powering a relay from a 12v power source, however this source does not immediately turn off, rather falls gradually for a 'fade' rather than straight off.
Unfortunately this makes my relay chatter multiple times in rapid succession open/closed just before it opens for the last time until next power on, as the voltage is just fluctuating around the critical level.
How can I avoid this? I tried some capacitors and while it helped I still wound up with it chattering at the end (Although slightly less).
  • \$\begingroup\$ you need to use a control circuit to activate the relay \$\endgroup\$ – jsotola Jan 27 at 0:33
  • \$\begingroup\$ What is your 12V source? What is causing slow turnoff (capacitors?) Can you build a crowbar or discharge circuit to ensure a clean shutdown? \$\endgroup\$ – EasyOhm Jan 27 at 0:58
  • \$\begingroup\$ Do I understand you to say that when you turn off the 12 V power source, the relay chatters a bit as the power source gradually declines in voltage? \$\endgroup\$ – jonk Jan 27 at 1:32
    \$\begingroup\$ Can you draw the schematics of what you are asking? It will really easy for others to understand the setup clearly \$\endgroup\$ – User323693 Jan 27 at 2:20
  • 4
    \$\begingroup\$ Normally relays have hysteresis. That is: the activate voltage and release voltage are far apart with release << activate. It should not chatter unless it switches off some equipment which then causes the operating voltage to rise again. I think we need a diagram of how it all is connected together. \$\endgroup\$ – Oldfart Jan 27 at 6:02
You can use an op amp to operate the relay:
When power is turned off, voltage starts to drop. once it reached 11 V, the op amp will deactivate the transistor base and turn off the relay.
|improve this answer|||||
  • \$\begingroup\$ For 12V coils you might want to pick a lower zener voltage though. 12V coils can typically operate reliably down to 9V or so. \$\endgroup\$ – Lundin Jan 27 at 7:50
    \$\begingroup\$ Suggest changing your opamp for a comparator, which is designed for exactly this sort of purpose. If you only have an opamp you can do it, but it's not the optimal solution. \$\endgroup\$ – awjlogan Jan 27 at 9:39
    \$\begingroup\$ @ElectronSurf - "faster" is not the reason to choose a comparator for this (although for a simple application an opamp will work, especially if you have a spare one on board already). Opamps are not designed to run open loop and have large differential voltages on their inputs, for example. Additionally, I would suggest putting in some hysteresis. \$\endgroup\$ – awjlogan Jan 27 at 11:14
