I picked up this (rather unique?) Tektronix spot welder at a sale a couple weeks ago. I haven't figured out whether it needs 120V or 220V service, and it didn't come with a power cord. The power should come through this male socket in the photograph.
Let me know if further details are needed. Thanks! Edits: - added front panel image. M
  • \$\begingroup\$ Looks nonstandard. Any other details available? (e.g. model number) \$\endgroup\$
    – user28910
    Jan 27 '20 at 18:30
  • \$\begingroup\$ I can't find anything that's positively the model number, just serial number 646. Tektronix headquarters is in my area (Portland, OR) and I imagine this was used as a part of their prototyping labs (maybe production?) back in the mid-20th century. I'll try to get measurements of the connector later tonight. \$\endgroup\$ Jan 27 '20 at 18:57
Looks like a variant of NEMA L-series TwistLock. The center hole is obscure. enter image description here
EDIT: closest one so far: 30 A 208Y/120 V L21-30 with two phases omitted. enter image description here
  • \$\begingroup\$ Thanks for the lead! The spot welder only has two pins, but maybe a 4-hole female connect works with it. I'll research these. \$\endgroup\$ Jan 27 '20 at 19:11
  • \$\begingroup\$ @JamesPalmer You’re welcome! Look at NEMA L21-30. One of these three phase variants with only one phase in use by your connector? \$\endgroup\$
    – winny
    Jan 27 '20 at 19:14
  • \$\begingroup\$ Sounds good. I'll measure the spot welder connector tonight and see if it matches the NEMA L21-30 specs. \$\endgroup\$ Jan 27 '20 at 19:31
  • \$\begingroup\$ @JamesPalmer Any success? \$\endgroup\$
    – winny
    Jan 28 '20 at 17:50
  • \$\begingroup\$ Thanks for following up. I measured a (roughly) 0.6" diameter at the pins. That seems to be too small for NEMA L21-30, which from eyeballing the drawing here has ~25mm has close to 1" diameter at the pins. internationalconfig.com/documents/L2130-C.pdf \$\endgroup\$ Jan 28 '20 at 21:33
After following up on winny's direction, it seems that I should be looking for an ML-2R connector.
  • \$\begingroup\$ Correct. Takes me back to the early 70's, building a TV station. Lotsa Tek gear. \$\endgroup\$
    – AnalogKid
    Jan 28 '20 at 21:54
