Following the discussion from this thread I am finalizing my calculations. I am not sure that I am calculating the power dissipation correctly. Given the following circuit powerdiss
I need to operate the opamp between 0-2.4V in 100mV steps, sometimes holding the values for 30min. With V_cc=3V and V_Bas=1V, V_Emit=0.5V. The collectorcurrent reads I_c=0.13mA and I_emit=0.043mA. At this conditions the Power loss calculates as
P_loss = (V_cc-V_Emit)*(I_c-I_emit)
I draw the power loss with the above formula over the range of V_in
power loss
Can I choose the right transistor based on this calculation (max ~430uW)?
  • \$\begingroup\$ Without getting bogged down in details, are you asking if finding a transistor that that dissipate a maximum of \$430\:\mu\text{W}\$ is hard to find? If so, the answer is "no, they are easy to find -- as the worst case is probably a TO-92 with about 200 C per watt or an increase of less than a tenth of one degree Celsius. It will be very hard to find a device with a problem with this dissipation -- and I'd love to hear about it, if you find one. \$\endgroup\$ – jonk Jan 28 '20 at 7:44
  • \$\begingroup\$ My main concern is if my calculation is correct \$\endgroup\$ – v3xX Jan 28 '20 at 7:46
  • \$\begingroup\$ Oh. Well power dissipation will be \$\approx V_\text{CE}\cdot I_\text{C}\$ when not saturated. Can you work out those details? \$\endgroup\$ – jonk Jan 28 '20 at 7:53
  • \$\begingroup\$ With Vce=Vcc-Ve? \$\endgroup\$ – v3xX Jan 28 '20 at 7:55
  • \$\begingroup\$ No, \$V_\text{CE}=V_\text{C}-V_\text{E}\$. But since (I think) \$V_\text{C}=V_\text{CC}\$ in this case (as I quickly see it) then perhaps so. \$\endgroup\$ – jonk Jan 28 '20 at 7:56
