Here is the Following circuit :
I don't know how the application note can assert that the voltage after the capacitor is equal to Vdrv-Vcl or -Vcl according to the driver output as there is a resistor Rgs ? Even with the clamp circuit it is just an RC circuit. Where is my error ?
The picture is extracted from this application note written by TI. http://www.ti.com/lit/ml/slua618a/slua618a.pdf
Thank you very much,
After enough time has passed, the voltage across Rgs will of course be zero volts, because as you rightly point out, it's an RC circuit.
However, a PWM controller will pulse the gate drive very quickly, much quicker than the RC time constant. In fact it's part of the design that you choose the RC time constant >> pulse length.
To put some typical numbers on it, let's say you have a 20v pulse, and the zener+diode combo will clamp the gate voltage to -5v. When the pulse output is low, the capacitor will charge to -5v, so that when the pulse is high, the gate will be taken to +15v (neglecting charge into the FET gate capacitance).
Think of it as a level shifter, not an RC filter. The time constant of the RC must be long compared to the PWM period.
It depends on the frequency of the signal and the rolloff of Cc and Rgs. If Fs >> 1/2*piCcRgs, the square wave is largely preserved, and the clamp becomes dominant. In that case, the above waveform is accurate in the short term; if the duty cycle is low, though, the clamp bias will bleed off and the next pulse will peak at Vdrv. The above is a good approximation for about 50% duty cycle and high frequency, assuming Vcl < Vdrv/2...if Vcl>Vdrv/2, the gate drive would swing between +/-Vdrv/2.
