I haven't seen any examples of registering ISRs in Atmel Studio 7, but I've given the following code a go in my IDE.
 * mainCode.cpp
 * Created: 1/29/2020 11:30:58 AM
 * Author : tuskiomi
#include "sam.h"
#define CPU_CLK 48000000 //CPU Clock Speed in Hz
#define SYSTICK_INTERVAL_MS 10 //System should always run at 100 Hz
#define SYSTICK_INTERVAL_CYCLES (CPU_CLK/1000*SYSTICK_INTERVAL_MS)-1
#define SYSTICK_CALIBRATION_VALUE (CPU_CLK/100)-1
void handleSysTick(){
int main(void)
    /* Initialize the SAM system */
    SystemInit();
        SCB->SCR &= ~SCB_SCR_SLEEPDEEP_Msk;
        uint32_t CPU = SCB->CPUID;
        uint32_t CPU_MINOR_REV = CPU&0x000F;
        uint32_t CPU_PART_NO = (CPU>>4)&0x0FFF;
        uint32_t CPU_MAJOR_REV = (CPU>>20)&0x00F;
        uint32_t CPU_IMPLEMENTOR = (CPU>>24)&0x00FF;
        //uint32_t SCB->
        SysTick->CTRL = 0x05;
        SysTick->LOAD = SYSTICK_INTERVAL_CYCLES;
        __NVIC_SetVector(SysTick_IRQn, ((uint32_t) *handleSysTick));
    /* Replace with your application code */
    while (1)
My main concern is with the line:
My c++ is very rusty, and what the expression ((uint32_t) *handleSysTick) is supposed to be is a uint32_t representation of the address that the function "handleSysTick" starts from. If this is indeed the case, then it is safe to say that the interrupt is properly configured.
  • \$\begingroup\$ Have you tried it? Seems pretty trivial to put this into the IDE and run it to see if it works... \$\endgroup\$ – Ron Beyer Jan 29 at 19:11
  • \$\begingroup\$ @RonBeyer I can build it, but I do not have a device to program, and I do not have the ability to simulate the device \$\endgroup\$ – tuskiomi Jan 29 at 19:25
  • \$\begingroup\$ SAMD21 boards are pretty easy to get, and relatively cheap. If you are going to be doing development for one, picking up a development board is almost as much of a requirement as downloading the IDE. Here's one, or an even cheaper one. \$\endgroup\$ – Ron Beyer Jan 29 at 19:30
  • \$\begingroup\$ @RonBeyer I have one being shipped to me. That's not an issue \$\endgroup\$ – tuskiomi Jan 29 at 19:37
    \$\begingroup\$ Set the appropriate switches for the compiler and linker you are using to force it to produce a disassembly of the code. You also need the linker to spit out a map of where everything is placed in memory. \$\endgroup\$ – Elliot Alderson Jan 29 at 20:32
