24
I am trying to debug a UART driver for the STM32F405. It does not work above a certain baud rate (about 50 kBd). I connected it to a logic analyzer with analog capability, and I saw that the signal is rounded; it takes time for the signal to rise. It seems that at higher baud rates the signal does not rise high enough for it to be read.
How can I allow the UART to function at higher speeds? I'm not sure if this is a hardware problem, or if it can be corrected in software.
Screenshot of logic analyzer, MCU transmitting at 38400 baud. A screenshot of the Saleae Logic program showing that the serial signal rises slowly, and does not quite reach to same level as longer signals
Screenshot of logic analyzer, MCU transmitting at 115200 baud. A screenshot of the Saleae Logic program showing that the serial signal rises slowly, with peaks not reaching nearly as high as full signal level.
More details:
  • I am reading the serial connection with a FTDI chip connected to my desktop.
  • I sniffed this connection with a Saleae Logic 8 connected to the same lines as the FTDI.
  • In the screenshots shown, the board is sending "testing" over the serial.
  • The MCU is part of an OpenPilot Revolution flight controller.
  • 8
    \$\begingroup\$ Is it an open drain output? It looks like one, with the pullup resistor too high (or missing) \$\endgroup\$
    – user16324
    Commented Jan 29, 2020 at 22:30
    \$\begingroup\$ @BrianDrummond Are you implying the OP has misconfigured his IO? \$\endgroup\$
    – DKNguyen
    Commented Jan 29, 2020 at 22:31
  • \$\begingroup\$ @DKNguyen Yes, since he's talking about an unspecified "driver" (line driver?) not the STM itself. Of course he might be talking about a device driver (software) in which case you have a point. Even then, it's possible for the pin to go open-drain, e.g. through ESD if not mis-configuration. \$\endgroup\$
    – user16324
    Commented Jan 29, 2020 at 22:35
  • \$\begingroup\$ @BrianDrummond. The driver I am referring to is the software on the microcontroller to control the UART, for the application to use. I don't know if the pin is open drain, but it is part of a board (OpenPilot Revo, mentioned in edit) that is intended to connect to peripherals directly without external resistors. \$\endgroup\$ Commented Jan 29, 2020 at 22:39
56
Check that the GPIO pin for UART TX is configured for alternative output push pull mode. It looks like it is configured for alternative output open drain.
  • 26
    \$\begingroup\$ The GPIO was configured as a open drain. Once I switched it, I was able to transmit 3 MBd accurately. \$\endgroup\$ Commented Jan 29, 2020 at 23:19
  • \$\begingroup\$ Curious to know if it is a legit FTDI chip or a bootleg. \$\endgroup\$
    – J.Hirsch
    Commented Jan 30, 2020 at 14:56
  • 4
    \$\begingroup\$ This has nothing to do with FTDI chip, that signal is output from microcontroller. \$\endgroup\$
    – Justme
    Commented Jan 30, 2020 at 15:15
    \$\begingroup\$ @MatthewNajmon, there is a history with FTDI and counterfeits. Also, of course a counterfeit would be less legit than a brand name and could obviously have more problems. \$\endgroup\$
    – JPhi1618
    Commented Jan 31, 2020 at 19:42
    \$\begingroup\$ @MatthewNajmon The FTDI controversy is long and boils down to manufacturers detecting and degrading their products. FTDI released driver patches that bricked chips. Counterfeiters patched it away. The results you're displaying on the logic analyzer may be compromised if counterfeit. The counterfeit chip may be running out of spec, may have bad capacitive coupling that degrades signal analysis, etc. It wasn't meant to get your hackles up and counterfeits are cheaper. Supply Chain Matters. I've been burned by the counterfeit issue even with a secure supply chain to the tune of $2k in junked gear \$\endgroup\$
    – J.Hirsch
    Commented Jan 31, 2020 at 20:04
7
Do you have a schematic for your circuit?
In addition to the misconfigured GPIO pin, another possibility is that you have a capacitor on your UART line, acting as a low-pass filter, and preventing the signal from rising quickly.
  • \$\begingroup\$ github.com/rosflight/airbourne_f4/blob/master/docs/… \$\endgroup\$ Commented Jan 29, 2020 at 23:10
    \$\begingroup\$ The port in question is the "main" port on the left, section C1. The other side is connected directly to the FTDI and logic analyzer. \$\endgroup\$ Commented Jan 29, 2020 at 23:11
  • \$\begingroup\$ Normally a low-pass filter would limit the fall rate as well as the rise rate. Why might not be the case here? \$\endgroup\$ Commented Jan 31, 2020 at 12:37
As mentioned above, setting it to output push-pull mode will solve the problem, however you may also want to check the "Maximum output speed" is set to 'very high', and if your system tolerates it, add the internal pull-up resistors; I know there's various schools of thought on whether USART should have pullups or not, so try it and see if it does what you want/need/project allows.
If you're using STM32CubeMX for your initialization/configurations, then these settings are all found in the pinout & configuration > USARTx (or UARTx, whichever channel you're using for your project) > GPIO Settings.
If you're just modifying the template file by hand (and presuming you're using the HAL libraries) then the pin settings should be in the src folder of your project, in the file called stm32F4xx_HAL_MSP.c (or whatever chip you're using)
You're looking for these lines;
GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
Make sure the GPIO.InitStruct.Speet is set to very high (as above) and set InitStruct.Pull to: GPIO_InitStruct.Pull = GPIO_PULLUP;
I've managed to completely abuse the UART on an STM32F4 and get it running at 15MB/s without losing bits, which was the fastest speed my FTDI to USB converter would operate at. I see though in the CubeMX settings, it says to keep it below 1MB/s.
  • \$\begingroup\$ Yes, the gpio is set to maximum speed. \$\endgroup\$ Commented Jan 31, 2020 at 18:12
