How long could I run a 115 Vac window unit on a 12v 200Ah battery (using a 700W inverter from a 400W solar panel and assuming 100% efficiency)? Thanks!
  • 5
    \$\begingroup\$ I'm voting to close this question as off-topic because homework-like questions should show what has been tried and narrow the question to one conceptual difficulty. \$\endgroup\$ – The Photon Jan 30 at 3:26
    \$\begingroup\$ This is not going to work. get a 12V air con. \$\endgroup\$ – Jasen Jan 30 at 5:21
    \$\begingroup\$ this cannot be answered ... you did not say how much power the window unit uses \$\endgroup\$ – jsotola Jan 30 at 5:47
A 700VA inverter can only produce 6A at 120V, it will not be able to start the compressor in a window AC. So, zero hours, unless you only run the fan.
|improve this answer|||||
i will give you most basic calculation
assuming your battery in good condition and new with trusted specification.
12*200=2400W/h this can steady until 1hours rate = 2400W total output
assuming your converter connected with load is 100% back to back without loss power which is highly unlikely.. 2400/700 = ~3.43Hours
the calculation with solar panel is different because you doesn't gives how much sunlight and how long it will directed to sun..
    \$\begingroup\$ Where does this 10 hours come from? \$\endgroup\$ – Ron Beyer Jan 30 at 3:58
  • \$\begingroup\$ oh yeah i forget.. its way overpowered it's discharge rate of some battery not leaded acid battery.. yes you are right only capable 3.42Hours. i will edit \$\endgroup\$ – XC Source Jan 30 at 4:04
