I am working on eeprom, i am getting the error as follow In file included from spi.c:65:
C:\Program Files (x86)\Microchip\xc8\v2.10\pic\include\pic18f4550.h:1726:3: error: typedef redefinition with different types ('union UEP8bits_t' vs 'union UEP8bits_t') } UEP8bits_t;
also my code is as follows:
#pragma config PLLDIV = 1 // PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1 // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator (HS))
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 21 // Brown-out Reset Voltage bits (2.1V)
#pragma config VREGEN = OFF // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config BBSIZ = BB1K // Boot Block Size Select bit (1KW Boot block size)
#pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) or (001000-001FFFh) is not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) or (000000-000FFFh) is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) or (001000-001FFFh) is not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) or (000000-000FFFh) is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) or (001000-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) or (000000-000FFFh) is not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdint.h>
#include<pic18f4550.h>
#define _XTAL_FREQ 20000000
#define _LEGACY_HEADERS
//--[ Pin Definitions ]--
#define Read RB0 // Read EEPROM Memory Blocks
#define W_3 RB1 // Write 0x03
#define W_5 RB2 // Write 0x05
#define W_7 RB3 // Write 0x07
//--[ Function Declarations ]--
void EEPROM_Write(uint8_t, uint8_t);
uint8_t EEPROM_Read(uint8_t);
void main(void)
//--[ IO Pins Configuration ]--
TRISB = 0x0F; // Push Buttons (Inputs)
TRISD = 0x00; // Output LEDs
PORTD = 0x00; // Initially OFF
uint8_t Address=0;
while(1)
if(W_3) // Write 0x03
EEPROM_Write(Address++, 3);
__delay_ms(500);
if(W_5) // Write 0x05
EEPROM_Write(Address++, 5);
__delay_ms(500);
if(W_7) // Write 0x07
EEPROM_Write(Address++, 7);
__delay_ms(500);
if(Address == 3)
Address = 0;
if(Read == 1)
// Read The EEPROM Data Out To PORTD LEDs
for (uint8_t i=0; i<3; i++)
PORTD = EEPROM_Read(i);
__delay_ms(1000);
return;
//--[ Functinos Definitions ]--
void EEPROM_Write(uint8_t Address, uint8_t Data)
while(EECON1bits.WR); // Waits Until Last Attempt To Write Is Finished
EEADR = Address; // Writes The Addres To Which We'll Wite Our Data
EEDATA = Data; // Write The Data To Be Saved
EECON1bits.EEPGD = 0; // Cleared To Point To EEPROM Not The Program Memory
EECON1bits.WREN = 1; // Enable The Operation !
INTCONbits.GIE = 0; // Disable All Interrupts Untill Writting Data Is Done
EECON2 = 0x55; // Part Of Writing Mechanism..
EECON2 = 0xAA; // Part Of Writing Mechanism..
EECON1bits.WR = 1; // Part Of Writing Mechanism..
INTCONbits.GIE = 1; // Re-Enable Interrupts
EECON1bits.WREN = 0; // Disable The Operation
EECON1bits.WR = 0; // Ready For Next Writting Operation
uint8_t EEPROM_Read(uint8_t Address)
uint8_t Data;
EEADR = Address; // Write The Address From Which We Wonna Get Data
EECON1bits.RD = 1; // Start The Read Operation
Data = EEDATA; // Read The Data
return Data;
'union UEP8bits_t'
? \$\endgroup\$ – Mike Jan 31 '20 at 9:56#include<pic18f4550.h>
\$\endgroup\$ – Mike Jan 31 '20 at 9:57#include<pic18f4550.h>
because if you have your project configured correctly, the#include <xc.h>
will do that for you. If you're getting conflicting definitions of that union then it's probably being declared in 2 different places and removing that include may fix your problem. \$\endgroup\$ – brhans Jan 31 '20 at 17:03
