What is the origin for the forumla: \$ R= {1\over2}V_{LSB} ={1\over2}*{V_{inMax}\over2^n-1} \$
Where does the \$ {1\over2} \$ comes from?
Shouldn't it be just: \$ R={V_{inMax}\over{2^n-1}}\$ ?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhat is the origin for the forumla: \$ R= {1\over2}V_{LSB} ={1\over2}*{V_{inMax}\over2^n-1} \$
If \$R\$ is the resolution as conventionally defined, then $$ R = \frac{V_{REF}}{2^N}$$ where \$R\$ is the resolution in volts, \$V_{REF}\$ is the internal reference voltage for the converter, and \$N\$ is the number of bits. The resolution is the smallest observable change in input voltage (for an ADC) or the smallest possible change in the output voltage (for a DAC). Note that the maximum observable/producible voltage is therefore $$V_{MAX} = R \times (2^N -1)$$ You need to be careful here, because the "maximum voltage" specification for an ADC may be the maximum input voltage that does not damage the ADC, not the maximum measurable voltage.
You can also talk about the uncertainty in an ADC input value, and the uncertainty is assumed to be plus or minus one-half of the resolution. I think perhaps you have mixed up the uncertainty and the resolution.
Your output step size is 1LSB, but the maximum distance (i.e. error) away from your truly desired value is 1/2LSB, when the desired value is halfway between two steps and you cannot get any closer to it.
