I am quite confused on how to implement a function using multiplexers. I know how to use a karnaugh map and get the necessary minimized function that I need, but I don't know how to implement it in logism using muxes.
For example, if I were to get the following function:
f = \$\Sigma\$ (6,8,9,10,11,12,13,14)
The answer would be A!C + A!B + BC!D.
However, how does that translate in logism? what would the select bits be? And how would you use the 4 inputs A,B,C,D? Would you have to use multiple muxes, or just one?
You can use a 16:1 multiplexer where A,B,C and D are the address lines and you set the appropriate (1 to 16) input lines to either 1 or 0 to get your required output. The minimal result from the karnaugh map doesn’t really help if you are going to use a multiplexer. This is the most useful formula in your question to aid you: -
f = Σ(6,8,9,10,11,12,13,14)
  • \$\begingroup\$ Thanks for the answer! I sort of get it now. I was overthinking which made me confused on how to do things. \$\endgroup\$
    – Jr194
    Commented Feb 2, 2020 at 0:53
