I am trying to design an op-amp but because it is going to be used at a max frequency of 10kHz, I only need to make sure the phase margin is good enough at this frequency. Most of the methods for designing op-amps that I found compensate the op-amp for the worst case scenario which is when it used as a buffer. However, in my case, it will never be used as a buffer. Is there a method I can follow that shows how to design an op-amp that is compensated at a particular frequency ?
Please see an image of the circuit: https://imgur.com/a/5IwOVge
The maximum frequency the input signal is 10kHz. The high-pass circuit sets the closed-loop gain at 40dB.
