Consider the above circuit, (the values are not correct). When I want to turn off the MOSFET, the output of the driver would be 0. If I have a large di/dt and a large parasitic source inductance, the voltage across L2 would be large and the driver won't be able to close the MOSFET, at least it will oscillate betwenn turn on and turn off until the di/dt be not enough significant for producing a voltage Vgs superior to Vdriver-vth ? Is this possible ?
It will help to turn off ...
Thank you very much.
