I have one ultrasonic transducer that is connected to high voltage Pulser (1-2MHz), I want to detect the ultrasonic signal generated by this transducer with other multiple transducers (~16). I have an electronic device that is able to receive analog signal (amplify+filter+ADC) from only one transducer. I am looking for a MUX that will allow receiving the analog signal (typically <500mV) from the 16 transducers sequentially (ADC is set at ~10MHz, pulse repetition is set at ~1-20kHz). What are the design considerations and MUX parameters that shall be taken into account while selecting a suitable MUX for this purpose?
Please note that I am looking only for a low voltage MUX, as the high voltage circuit is separated from the receiving circuit.
  • \$\begingroup\$ Questions about recommendation of specific part numbers are off topic here. You can solve your problem using the parametric search of any major online distributor of chips. \$\endgroup\$ Feb 3, 2020 at 8:29
    \$\begingroup\$ @VladimirCravero - thank you for your comment. I rephrased the question based on your comment. \$\endgroup\$
    – atrash
    Feb 3, 2020 at 8:40
The selection of the MUX will depend on the key parameters that you are designing to maximise/minimise.
If your goal is to maximise SNR, SINAD or minimise phase error you will need different mix of parameters.
  • For SNR maximising, you'll need to match impedance to ensure energy transfer and minimise cross-talk between channels.
  • For SINAD, you'll need to consider the bandwidth of the MUX as well to minimise distortion.
  • For phase error you'll also need to consider electrical TX/RX impedance matching. For details on this - if you are not already familiar with this topic - you can look here (p65/68) or search for ultrasonic reciprocity (often mentionned in flow meter litterature).
You will also need to consider how the Coff and Con parameters aggregate when considering your impedance matching
