I want to use a buck converter based on IC AOZ1284PI from Alpha & Omega Semiconductor. AOZ1284PI is a low cost buck controller. For example, on Digikey it costs USD 0.51 @ 500 whereas the TPS54340 from Texas Instruments costs USD 2.53 @ 500. The IC support up to 4A of continuous output current, so I want to use it to reduce a 12V rail to a 5V rail capable of delivering 4A. Below are the parameters that I used to make the calculations using the equations shown in the datasheet. I have calculated RC to be 180K ohms e CC to be 1.5nF. I would like to ask if somebody can do a revision on these calculations, and check if these values are really suitable, the value of CC and RC on schematic, that goes connected to COMP pin.
Datasheet: http://www.aosmd.com/res/data_sheets/AOZ1284PI.pdf
Parameters:
- Vfb = 0.8V
- Vout = 0.8 + (0.8 * 1800/330) = 5.15V
- Iout = 4A
- CO = 141uF
- COesr = 5 mOhm
- inductor = 4.7uH 8x8x4mm (SRN8040TA-4R7M). Current 5.8A. Saturation 6.7A
- FSW = around 1MHz (47K 1% resistor)
- fc = 30KHz (crossover frequency) or maybe 5khz if better
- Vin = 12V
- RL = 5.15V / 4A = 1.28 Ohm (datasheets states RL)
Calculations:
- fp1 = 1 / (2pi * CO * RL)
- fp1 = 1 / (6.28 * 141 uF * 1.28 Ohm)
- fp1 = 1 / (6.28 * (141*10^-6) * 1.28)
fp1 = 882.2
fz1 = 1 / (2pi * CO * esrCO)
- fz1 = 1 / (2pi * 141 uF * 5 mOhm)
- fz1 = 1 / (6.28 * (141*10^-6) * (5*10^-3))
fz1 = 225866.2
RC = fc * (VO/VFB) * ( (2pi * CO) / (GEA*GCS) )
- RC = 30000 * (5.15/0.8) * ( (6.28*(141*10^-6)) / ((200*10^-6)*(4.5)) )
- RC = 190009.25
RC = 180K...
CC = 1.5 / (2pi * RC * fp1)
- CC = 1.5 / (6.28 * 180000 * 882.2)
- CC = 1.5*10^-9
- CC = 1.5nF...
Then, finally
- fp2 = GEA / (2pi * CC * GVEA)
- fp2 = (200*10^-6) / (6.28 * (1.5*10^-9) * 500)
fp2 = 42.4
fz2 = 1 / (2pi * CC * RC)
- fz2 = 1 / (6.28 * (1.5*10^-9) * (180000))
- fz2 = 589
Schamatic:
Below I show my current layout, from top layer:
On the bottom layer, I have a good ground poor.
Regards.
EDIT1 Schematic and layout after user Verbal Kint answered to the question. 12V input, 5V output @ 4A
