I need to find the small signal parameter \$r_{D1}\$. I understand I must draw the small signal equivalent first, but I do not know where to label this resistance, or what exactly it is equal to. Also is \$v_{dd}\$ labeled correctly?
You just need to apply the usual method to determine the resistance seen from two terminals, here being \$v_o\$ (gate-drain terminal) and ground. Turn off all the sources. The circuit is
Calculate \$i_x\$ and calculate vx/ix i.e. \$r_{d1}\$, which should be trivial.
For that circuit, with diode-tied gate-drain connection, the dynamic resistance will be the transconductance.
For long-channel FETS, the transconductance is just the derivative of Idd(Vgate), or
2 * KW/L * Ve
where K = Mobility * Cox, and Ve = Vgs = Vt
To derive this maths, write the triode-region small-signal iout(vgate) equation, and apply your skills.
