I am trying to understand the block diagram of the TXS0108E bidirectional logic shifter. In the chip's description it says
When the output-enable (OE) input is low, all outputs are placed in the high-impedance (Hi-Z) state.
However at page 18, this block diagram is given:
There are pull ups at both the Va and Vb side pins, so if the gate at the centre is not turned on, shouldn't the Va and Vb side pins have a voltage of Va and Vb respectively?
If I understand correctly, something like this would give a high impedance output when the input level is 0
but the pull ups in the TXS0801E chip should prevent the output from going high impedance. So what does it mean when it says the chip outputs are placed in high impedance when the OE pin is set to low?
