I wrote a custom bootloader for the STM32F4 microcontroller and I'm able to write an application to the flash memory at the address of 0x08008000. The issue I have is when I use the jump function the application doesn't seem to execute. I have attached the jump function below. I have disabled all the peripherals, timers and interrupts. Also, relocated the vector table to 0x08008000 to run the new app.
void bootloader_jump_to_user_app(void)
   //just a function pointer to hold the address of the reset handler of the user app.
    void (*app_reset_handler)(void);
    //shut down any tasks running
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_10);
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_11);
    HAL_TIM_Base_Stop_IT(&htim4);
    HAL_TIM_Base_DeInit(&htim4);
    HAL_RCC_DeInit();
    HAL_DeInit();
    SysTick->CTRL = 0;
    SysTick->LOAD = 0;
    SysTick->VAL = 0;
    //disbale interuppts
    __set_PRIMASK(1);
    __disable_irq();
     SCB->VTOR = FLASH_SECTOR2_BASE_ADDRESS; //0x080080000
    // 1. configure the MSP by reading the value from the base address of the sector 2
    uint32_t msp_value = *(__IO uint32_t *)FLASH_SECTOR2_BASE_ADDRESS;
    __set_MSP(msp_value);
    uint32_t resethandler_address = *(__IO uint32_t *) (FLASH_SECTOR2_BASE_ADDRESS + 4);
    app_reset_handler = (void*) resethandler_address;
    //3. jump to reset handler of the user application
    app_reset_handler();
In the linker file for the bootloader I have broken the flash into two parts, one for the app and the other for the bootloader. For the application linker file I have the flash starting at 0x08008000.
/* Memories definition */
MEMORY
    CCMRAM  (xrw)   : ORIGIN = 0x10000000,  LENGTH = 64K
    RAM (xrw)   : ORIGIN = 0x20000000,  LENGTH = 128K
    FLASH   (rx)    : ORIGIN = 0x8000000,   LENGTH = 128K
    APPLICATION (rx) : ORIGIN = 0x08008000, LENGTH = 896K
  • \$\begingroup\$ How/where is FLASH_SECTOR2_BASE_ADDRESS defined? Is it just an integer or is it already a pointer of some sort? \$\endgroup\$
    – brhans
    Commented Feb 5, 2020 at 16:05
  • \$\begingroup\$ defined in header file as #define FLASH_SECTOR2_BASE_ADDRESS 0x08008000U \$\endgroup\$
    – doge
    Commented Feb 5, 2020 at 16:08
  • \$\begingroup\$ I have an STM32F4 bootloader which does something like: extern uint32_t __FLASH_segment_start__[]; #define APPLICATION_START (uint32_t)__FLASH_segment_start__ SCB->VTOR = (uint32_t)APPLICATION_START; __set_MSP(APPLICATION_START[0]); ((void (*)(void))APPLICATION_START[1])(); and it seems like your code _should have the same effect ... \$\endgroup\$
    – brhans
    Commented Feb 5, 2020 at 16:15
  • \$\begingroup\$ code seems similar. Maybe there's something that i missed since my jump function doesnt work \$\endgroup\$
    – doge
    Commented Feb 5, 2020 at 16:26
    \$\begingroup\$ Did you link your code to start at 0x08008000? You can't just take an image linked for a different start address, load it, and expect it to work. \$\endgroup\$ Commented Feb 5, 2020 at 18:47
I managed to get the bootloader to work. I just needed to rename the reset_handler in the linker script and startup_stm32F40xx.s file to bootloader_reset_handler for the bootloader program.
  • \$\begingroup\$ Can you please tell me how you renamed reset_handler in the linker script and startup_stm32F40xx.s file \$\endgroup\$
    – Rohith R
    Commented Sep 15, 2021 at 6:13
Renaming reset_handler in the linker script and startup_stm32F40xx.s file
  1. Open STM32XXXXX_FLASH.ld file in your project search text Reset_Handler. replace this text with Boot_Reset_Handler.
  2. Open startup_stm32F40xx.s file in startup folder search text Reset_Handler. replace this text with Boot_Reset_Handler for all occurances.
